Try opening the idle mixture screw a quarter turn.
It does seem strange that it is ok at idle and WOT, almost like you ended up on the wrong clip position.
JimDirt wrote:1 other thing on the carb , have you replaced the Needle Jet (this is the long tube that the main jet screws into and the Needle goes into) , if it is worn it will cause all sorts of issues from idle changing from one minute to the next , to rich and lean conditions , especially when you have the needle on the 5th clip position , maybe try putting the needle on the 4th position , and/or replacing the Needle Jet (it should be around $8.00 u.s.)
You will not be able to really see any wear , but what happens is it will oval out and make the needle gap change without moving the throttle itself , this will cause the carb to run rich then lean without even touching the throttle because just the vibration of the engine running will bounce the needle around , so you could come into a corner and it will just richen up or lean out and stall
Not saying this is it , but its one more thing to eliminate and is relatively inexpensive
Users browsing this forum: Bing [Bot] and 12 guests
