by madmax » Wed Jan 31, 2007 5:51 pm
Only one of mine went to zero, it would still start first kick. I went ahead and replaced just that one valve. A closed valve will ruin the seat if left too long and might break and cause lots of damage$$$$$.
Just follow the owners manual for removing the head, take it to a good shop that will cut the seat, and buy a valve, spring, and head gasket from service honda. A little over $100 and a day in the garage and your good as new.
A good tip to remember is once you have it at TDC you`ll have to rotate it 180 and remove that bolt on the cam gear, then back to TDC and remove the other. Everything else in the owners manual is very clear.
03 450R
02 GXSR1000
05 250X (kid #1)
05 250X (kid#2)
