engine mount bolt breaking on 100
  • crf100rider21
    by crf100rider21 » Tue Mar 14, 2006 5:30 pm
    on my crf 100 the engine mount bolt keeps breaking after jumping the bike. I have had to replace this bolt 5 or 6 times and it gets kind on annoying having to buy and replace it all the time.
    I do not jump the bike that big but it always seems to break
    anyone else have this problem
    the bolt is on the very bottem of the bike running under the engine behind the left side foot peg goes all the way through
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    protaper bark busters
    Mazda b2300
    tinted windows
    custom sound system
    flo tec with dauls commin out the back
    oldtimer
    by oldtimer » Tue Mar 14, 2006 6:19 pm
    Are you replacing it with the Honda part or a hardware store same size part?
    The reason I ask is a bolts tensile strength varies greatly.
    I’m assuming your replacing it with a metric bolt. If so ensure it has a 10.9 stamped in the head as a minimum or better yet a 12.9. The 12.9 is an alloy steel rather than straight steel.
    06 CRF80
    04 CRF70
    88 CR250
  • crf100rider21
    by crf100rider21 » Wed Mar 15, 2006 1:08 pm
    I am eplacing it with just a hardware store becous the closest honda shop to my hous is about an hour away and it is way more expensive. I will try buying one from the honda shop and see if it breaks
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
    oldtimer
    by oldtimer » Thu Mar 16, 2006 5:09 am
    You do not need to get it from Honda. That said the Honda bolts are very nice Flange head hardware. If you have a Fastener shop in the area or even at your hardware store you can pick one up but just be sure to read the markings. Look for Metric bolts that have a min of 10.9 stamped on the head. If they have a 12.9 in your size that’s better!
    06 CRF80
    04 CRF70
    88 CR250
  • crf100rider21
    by crf100rider21 » Thu Mar 16, 2006 1:27 pm
    ok i will ask for a 10.9 bolt and if they don't have one then i will jeust keep getting the same thing it only takes about 5 mins to change now and cost about 20 cents
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
