how do i put in a new clutch
  • crf100rider21
    by crf100rider21 » Tue Mar 14, 2006 5:17 pm
    The clutch is slipping on my crf 100 and i was hopping that i could fix that with a simple ajustment but that dose not look like that will happen so if anybody knows how to put in a clutch or knows a place that can tell me how please do
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    protaper bark busters
    Mazda b2300
    tinted windows
    custom sound system
    flo tec with dauls commin out the back
    450xL.W.
    by 450xL.W. » Fri Mar 24, 2006 12:47 am
    get a cluch kit,cluch cover seal and 2 boteles of oil, drain you're oil, lay you're bike on it's side (rear brake lever up) remove brake lever and cover, soak new fiber cluch plates in new oil fore 1 hour, remove cluch spring bolts lift out top presure plate and springs, remove all cluch plates fiber and metal then start instaling them first fiber then metal until alnw plates are in ,reinstall presure plate and new springs install spring bolts, side cover and seal, brake pedel and fill with new oil. If you have never atemted somthing like this I highly recomend geting a service manual so you can folow along it will lead you beter than i can from hear.
  • crf100rider21
    by crf100rider21 » Sat Mar 25, 2006 2:24 pm
    that sounds easy anough are there any speacial tools i might need what is the best brand of clutch pack to get in a reasinable price range
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
    450xL.W.
    by 450xL.W. » Thu Mar 30, 2006 9:46 am
    regular hand tools should be fine. I like EBC or Barnett cluches myself, but I have never priced one for that bike.
    05 450Xr
