by JimDirt » Sun Jul 26, 2020 9:02 am
My guess is you either pinched the tube while installing , or the rim lock has burrs on it and a sharp edge where the metal part is , and it is cutting the tube .... either way , looks like you will be pulling the tube out again , whether you can patch it depends on the cut/pinch location and size ....... you may be able to patch it with a patch kit , or you may end up having to buy another tube
The biggest mistake when changing tires/tubes is trying to grab too large a bite with the tire spoon/iron , you end up pulling the bead too tight and either the tube gets caught in between and is pinched , or you actually tear it with the spoon ...... small sections is all you need to go , maybe 1-3 inches at a time , many small bites with the spoon is better than just a few big ones to try to hurry getting the tire on , making sure that the tire bead on the opposite side of the rim (not across the rim , but on the flip side of the rim) is still not seated , as that will make the tire harder to get on , even soaping the bead of the tire with a spray bottle of Awesome or diluted dish soap will ease installation and make the bead go over the lip of the rim easier , as opposed to installing it dry , you do not want the bead in place till you have the entire tire spooned over the rim lip on both sides , then let the air when filling seat the bead , you can also use Baby Powder to coat the tube itself before installing , it makes is slicker and less likely to catch in the bead .......
But what I would check , is the rim lock , and run your hand along the edges of the metal part , if it feels rough or sharp , then it is sharp enough to cut the tube , so sand or file the edge of it and try to round the edge , so it is smooth/dull, much like the back side of a butter knife , rather than like the edge you cut with , that is most likely the issue ....
