CRF 80 Revs at half Choke?
Posted: Thu Jul 26, 2018 10:32 am
Hi,
I just purchased a 2004 CRF80F and it fires right up when choked and then when you go to push to choke down it revs the engine until the choke is all the way down and then it idles a little rough and wants to die unless you give it throttle. It has sat alot and I know tht carb probably needs cleaned or the jets replaced, but whats with the high engine RPMS as you close the choke??? Thanks in advance!
Tye
Tye
