whats wrong with my daughters CRF100F
Posted: Sat Jul 11, 2009 8:12 am
by 230rider
Hi guys, i am sure you have a solution to my problem.....my daughters CRF100 will stall every time she shifts her bike into 1st gear...what could it be.........the gas is flowing fine and runs good while riding. She just has trouble when shifting into 1st gear......thankyou in advance............Don
Posted: Sat Jul 11, 2009 9:30 am
by Wilcox
idle too low?
Posted: Sat Jul 11, 2009 9:40 am
by motosicko
Is the clutch adjusted properly? Freeplay at the lever? Proper trans. fluid level and oil type? Clutch basket have grooves worn in it? Guess what i'm getting at is it sounds like a clutch dragging problem.
Posted: Sat Jul 11, 2009 9:52 am
by 230rider
what she didnt tell me is that it is running a little rough...................it might need a carb cleaning......
Posted: Mon Jul 13, 2009 12:28 am
by JohnSBA
Can't hurt to clean the carb, and especially the pilot jet. My daughters 100 was also running poorly last time out - hanging idle, couldn't seem to get the idle to stay consistent, etc. The bike had not been ridden for 6 months, and the pilot jet was plugged from varnish. Cleaned that up and we were good to go. I'd also suggest if you are going to be in the carb anyway, replace the jets; go with 38 pilot for sure, and optionally step up to a 102 main.
Posted: Mon Jul 13, 2009 12:50 pm
by rocketman
Still sounds like the clutch is hanging, Check the adjustment. Happy riding...........
Posted: Fri Jul 17, 2009 5:38 am
by DIRTSHR3DD3R
Is there a nuetral safety switch on that bike?
my daughters 100
Posted: Sun Nov 29, 2009 2:42 pm
by 230rider
Hey guys i never got back at you, buut the problem was a clutch adjustment. Took 2 minutes.....thanks for all the advise....sorry i took so long to get back at ya. I been so busy.....Don
Posted: Sat Jan 30, 2010 12:33 pm
by fmhscracer
I have an '04 rm 125, and when warm if it idles 2 long itll jump, as if i popped the clutch, so i bet its the same problem.
