whats wrong with my daughters CRF100F
  • 230rider
    by 230rider » Sat Jul 11, 2009 8:12 am
    Hi guys, i am sure you have a solution to my problem.....my daughters CRF100 will stall every time she shifts her bike into 1st gear...what could it be.........the gas is flowing fine and runs good while riding. She just has trouble when shifting into 1st gear......thankyou in advance............Don
  • Wilcox
    by Wilcox » Sat Jul 11, 2009 9:30 am
    idle too low?
    motosicko
    by motosicko » Sat Jul 11, 2009 9:40 am
    Is the clutch adjusted properly? Freeplay at the lever? Proper trans. fluid level and oil type? Clutch basket have grooves worn in it? Guess what i'm getting at is it sounds like a clutch dragging problem.
    "There are old racers
    and there are bold racers,
  • 230rider
    by 230rider » Sat Jul 11, 2009 9:52 am
    what she didnt tell me is that it is running a little rough...................it might need a carb cleaning......
  • JohnSBA
    by JohnSBA » Mon Jul 13, 2009 12:28 am
    Can't hurt to clean the carb, and especially the pilot jet. My daughters 100 was also running poorly last time out - hanging idle, couldn't seem to get the idle to stay consistent, etc. The bike had not been ridden for 6 months, and the pilot jet was plugged from varnish. Cleaned that up and we were good to go. I'd also suggest if you are going to be in the carb anyway, replace the jets; go with 38 pilot for sure, and optionally step up to a 102 main.
    2018 Yamaha YZF-R1
    2017 Ducati Multistrada 1200s
    2006 Honda CRF 250x (stolen)
  • rocketman
    by rocketman » Mon Jul 13, 2009 12:50 pm
    Still sounds like the clutch is hanging, Check the adjustment. Happy riding...........
  • DIRTSHR3DD3R
    by DIRTSHR3DD3R » Fri Jul 17, 2009 5:38 am
    Is there a nuetral safety switch on that bike?
  • 230rider
    my daughters 100
    by 230rider » Sun Nov 29, 2009 2:42 pm
    Hey guys i never got back at you, buut the problem was a clutch adjustment. Took 2 minutes.....thanks for all the advise....sorry i took so long to get back at ya. I been so busy.....Don
  • fmhscracer
    by fmhscracer » Sat Jan 30, 2010 12:33 pm
    I have an '04 rm 125, and when warm if it idles 2 long itll jump, as if i popped the clutch, so i bet its the same problem.
    FMHSC
    '09 #1150
    '10 #981
