crf 100
  • haralson
    crf 100
    by haralson » Tue May 10, 2005 8:04 am
    my son,s crf100 will only run with the choke in the middle position. It bogs down at higher rpm settings. Have adjusted idler screw, cleaned air filter, changed spark plug. No change. Any ideas?
    Adam R.
    by Adam R. » Tue May 10, 2005 3:59 pm
    how many tanks of gas have u been through? if the answer is five, u need to get the valves adjusted.
    If your not having fun, your doing it wrong.
  • VDTRA 38x
    Re: crf 100
    by VDTRA 38x » Tue May 10, 2005 7:58 pm
    haralson wrote:my son,s crf100 will only run with the choke in the middle position. It bogs down at higher rpm settings. Have adjusted idler screw, cleaned air filter, changed spark plug. No change. Any ideas?
    The bike is running lean. Have you done any mods to it? Changed something? Anything?
