jetting
    zak13
    jetting
    by zak13 » Sun Aug 26, 2007 10:20 am
    if my carb is stock with the fuel screw 2 turns out if i move my needle to the 4th position will i have to get whole new jets or can i get away with just doing that
    sellin my xr100
    by Skoot22 » Mon Sep 03, 2007 10:04 pm
    you can just do that.
    zak13
    by zak13 » Tue Sep 04, 2007 5:59 am
    okay thanks and how do i remove the clip from the needle
    sellin my xr100
    by Asmith » Tue Sep 04, 2007 6:06 am
    zak13 wrote:okay thanks and how do i remove the clip from the needle
    Needle nose pliers.
    zak13
    by zak13 » Tue Sep 04, 2007 1:37 pm
    i tried and it wont come off
    sellin my xr100
    by Skoot22 » Wed Sep 05, 2007 12:26 am
    lay the needle down on a hard flat surface and push the needle down from the top just above the clip so you dont bend it, with the open side of the c-clip facing down toward the surface, it should pop right off. Dont lose it. and do the same to get it back on, open side of clip facing up of course. Or use pliers to get it back on.
