Carb leaking fuel
  • WillCRF
    Carb leaking fuel
    by WillCRF » Mon Mar 07, 2005 4:40 am
    My son's '02 XR100 is leaking fuel from the drip tube connected to the float chamber when the engine is at idle speed. You can see fuel dripping on the ground. The engine starts and seems to run fine. I noticed the plug was fouled which indicates a rich mixture. Does anyone have any ideas where to look first? Thanks.
    by crfsonly » Mon Mar 07, 2005 8:40 am
    my guess is the float needs to be set correctly.
  • WillCRF
    by WillCRF » Mon Mar 07, 2005 10:38 am
    crfsonly,
    Thanks for your suggestion. I actually suspected the float height to be the first thing to check. Is this something I can measure by removing the float chamber bowl without removing the carb from the bike? Thanks again for your help.
    Will
  • gincognito
    by gincognito » Sun Nov 13, 2005 10:46 am
    This is an old thread but my advice to anyone having this problem is to replace the needle valve. I had the same problem on my DRZ400 and I dickered around with the float, cleaned the carb, etc. etc. I must have taken the carb out three or four times (a pain). Finally, I changed the needle valve and the leak was gone immediately.
  • WillCRF
    by WillCRF » Sun Nov 13, 2005 5:45 pm
    Actually this was a float issue if I remember. I simply removed the carb, took the bottom off and cleaned the float chamber. Must have been something messing with the float because this did the trick.
    Will
    '05 450x (Rekluse)
    '07 KTM 250XC-W (Rekluse)
    '05 KTM 200exc (Son #2)
    '06 KTM 200xc (Son #1)
