VDTRA 38x...
I put in the 112 main jet but I am getting some deceleration popping and also it cuts out if I throttle to hard off idle.
I removed baffle but have not done the air box yet.
Any ideas?
[/quote]crf100rider wrote:I just bought a new crf100f. I'm about 5'7 and 135 lbs. The bike is great i mean it is a honda. My only complaint is it isn't track material. I don't know a lot about four strokes so if anyone has any advice on parts to make it track worthy i would appreciate it.
Well I've one as well and I live in Huntington West Virginia and if you want to make faster do what I'm gonna do I'm gonna lower my front sprocket to a 13 tooth sprocket and raise the back to a 52 tooth sprocket the stock sizes you have right now is a 14 tooth front and 50 tooth back so you do that and it will run like a CR80 EXPERT!!! and then. Now for hitting jumps you want to stiffen your suspension and you can do it for free by looking on the bottom of your shock and you will find a place to pump it up with air like a bicycle tire but you also have to loosen a screw that is in a wire that runs to your shock but don't unscrew it all the way because it will fly off just unscrew it a little bit then add air to the bottom of the shock the screw is located in the wire which is around the top of the shock and the air tube to fill the shock is at the bottom of the shock if you want to know more e-mail me at [email protected]
If you dont ride red
stay in bed
