New 06 150 problem
    In2deep
    New 06 150 problem
    by In2deep » Thu Oct 12, 2006 8:36 pm
    Not sure where to start.
    I just bought a 150f for my wife and it has not yet been ridden. I would like to take it out this weekend so I have been outside checking it out. It has been very difficult to start and keep running to the point that the battery went dead from trying to start it. ( Yes I understand the choke)
    I bought a charger and made sure the battery was charged, I turned up the idle a bit and I can get it to start and stay running after several tries.
    Here is the real problem ....
    Once it is started and it begins to idle on its own it just stalls if you touch the gas.
    The bike is warm. A slow rev/roll of the rottle gets me a slight rev. If I hit it quick or more than a 1/4 it lags with no rev and then stalls.
    This does not seem right......
    What am I doing wrong or is there a problem with this bike? It is 100% stock 1 week old never ridden.
    I am sorry if this is a simple question with a simple answer but my 450 does not do this.
    Re: New 06 150 problem
    by Asmith » Thu Oct 12, 2006 8:44 pm
    In2deep wrote: A slow rev/roll of the rottle gets me a slight rev.
    I think it might be missing a "Th".
    Pull the air filter off and start it again and see if problem persists.
    You did turn the fuel on right?
    I had to ask...
    In2deep
    by In2deep » Thu Oct 12, 2006 8:46 pm
    Are you saying start it with no filter?
    Yes the gas is on.
    by Asmith » Thu Oct 12, 2006 8:47 pm
    In2deep wrote:Are you saying start it with no filter?
    Yes the gas is on.
    Yes.
    In2deep
    by In2deep » Thu Oct 12, 2006 8:58 pm
    Yep same thing.
    ideas?
    by Asmith » Thu Oct 12, 2006 9:05 pm
    OK, here's how the Carb works:
    The Pilot jet controls the flow of fuel from idle to 1/4 throttle. This is adjusted by the Fuel Screw (which I'm betting isn't adjustable on the 06 CRF 150F).
    The Needle controls fuel flow 1/4 and 3/4 throttle.
    The Main jet controls fuel flow 1/2 to WFO throttle.
    In2deep
    by In2deep » Thu Oct 12, 2006 9:08 pm
    It would make sense to me that this thing is too Rich right? Add throttle = stall? So opening up the filter to let air in seems like a fix. Perhaps not enough of a fix.
    there is no fuel screw on this bike.... and the manual says under carb...
    Your bike will run rich at high altitude.
    If your bike has been adjusted to run at high altitude and you move it to a lower altitude it will not run as well.
    THAT IS ALL. Why do they even give you a manual.
    They should just give you a rock and say if you have a problem hit yourself with this.
    by Asmith » Thu Oct 12, 2006 9:09 pm
    It seems that your issues are with the pilot jet.
    You might pull the float bowl off the carb and make sure the pilot is clean.
    The bike should've come with a 6 month warranty.
    You might want to check with the dealer before doing any work yourself as to not void the warranty.
    In2deep
    by In2deep » Thu Oct 12, 2006 9:25 pm
    Thank you,
    That is the plan. I will take it in tomorrow. I should not have to mess with a new bike.
    by Asmith » Thu Oct 12, 2006 9:32 pm
    In2deep wrote:Thank you,
    Agreed!!
    That carb is a simple one and I'm sure we can figure it out, but you shouldn't have to. Cross that bridge when they tell you to pack sand.
    by nminus1 » Thu Oct 12, 2006 10:17 pm
    Sean try cleaning the pilot jet. Its better than a trip to the stealership if it works. Unscrew it out, and clean it with a small piece of wire cut from a wire brush, held with a pair of small needle nose pliers. Then put a $4 in-line filter in the gas line for future. Oh yeah then put in some AV gas and hold on....
    by Asmith » Fri Oct 13, 2006 6:35 am
    nminus1 wrote: Oh yeah then put in some AV gas and hold on....
    Dammit! I'm gonna have to try that AV gas thing! Every time you mention it I wonder...
  • dk54red
    by dk54red » Fri Oct 13, 2006 6:42 pm
    In2deep wrote:It would make sense to me that this thing is too Rich right? Add throttle = stall? So opening up the filter to let air in seems like a fix. Perhaps not enough of a fix.
    Here is where the fuel screw is and it is a pain to adjust. It is the brass d shaped thing. I also did a post of the re-jetting of an 06 150 carb http://crfsonly.com/forum/viewtopic.php ... b9b358fa44
  • Vanrock
    by Vanrock » Sat Oct 14, 2006 4:32 am
    How high are u up??
    My bike in winter (15*C) has this problem just start ya bike on full choke half rev and keep reving on about 1/4 throttle and turn of the choke. 150's take a long time to warm up like 2 minutes to stay idling by them selves. i have since drilled holes in my baffle with not much noise increase. this helps my bike to start.
    In2deep
    by In2deep » Sat Oct 14, 2006 4:05 pm
    Well... the 150 takes a ridiculous mount of time to warm up is right.
    Yesterday in my garage it did take about two minutes to get the thing to idle on its own. I ended up turning the idle way up so it would stay running. I let it idle for more than 15 minutes and then went back to mess with it. It would still bog some but less than before and if I kept playing with it I could get it to stall. I let it continue to idle for a while as I read through the manual again and called the dealer.
    The response from the dealer. " Those bikes take forever to warm up"
    So back outside I go It still bogs some but even less this time and almost like it should be. At least I could not stall it with the throttle this time.
    So I guess the problem is that it needs to be WAY WAY warm in order to kill the bog. Very unlike my bike.
    I went riding today and as soon as we got to the place we were going to ride I started the bike, turned up the idle and let it sit there running while I got dressed, dressed my wife and gave her a refresher course. About 15 minutes.
    She hopped on and stalled it a few times and then a short ride later we could not stall it and it started instantly upon touching the button every time we stopped.
    It looks like the problem is solved for now.
    Thank you everyone for all of the help.
