CRF150F- Powroll High Compression Race Performance Package
  • CRFpride*
    by CRFpride* » Mon Jan 31, 2005 12:42 pm
    has anybody bought onea these???????....tell what u think of it, plz. also,......it says to use race gas 100octane min. does anybody actually do that????? does it realy matter?? sry for all the Qs. this is my first bike, iv had it for 3 years now, and NO upgrades, i think its finally time,. i ordered the package lastnight with my dad. and im hoping u guys can help me with my few uncertainties. thanks.
  • HondaMXpunk
    by HondaMXpunk » Tue Feb 01, 2005 11:40 am
    Powroll products are great. Yes, you have to use 100 octane race gas mix. The compression ratio is raised and needs higher octane gas. Although, you can get pump gas and add octane boost. I'm not 100% sure you can do this, but I am almost 100% sure.
  • CRFpride*
    by CRFpride* » Tue Feb 01, 2005 1:22 pm
    hondaMXpunk, thanks for the advice, i just wasnt sure about if it realy mattered, i think i got it figured out for awhile.
    has anyone bought the BBR fork springs/rear springs,
    i bought these 2, how hard is it to make the swap, 200lbs. big kid, know, do u think these will hold me better?
  • CRFpride*
    by CRFpride* » Tue Feb 01, 2005 5:48 pm
    ok, i have to use HIGH octane feul, but iv only got the stock valves in it,.....im afraid of burnin them,.....if i dont run high octane what will happen to the motor??
  • VDTRA 38x
    by VDTRA 38x » Tue Feb 01, 2005 8:09 pm
    High octane (100) gas does not burn hotter then standard (89). What it does is resist pre ignition that happens in high compression engines. If you don't use it in a high compression engine you will get a pinging or knocking noise from the engine. The gas actually starts to burn before the spark plug ignites it.
    by crfsonly » Tue Feb 01, 2005 9:26 pm
    you can actually serverly damage your high compression engine if you don't run the higher octane fuel. if the piston is coming up on the compression stroke and the mixture ignites prematurely it can send a pretty strong force in the wrong direction...can you say breaking stuff along the way? run the race gas mix and you'll have a happy motor...happy motors make happy riders.
  • CRFpride*
    by CRFpride* » Wed Feb 02, 2005 4:19 am
    ok thanks for the tips, ill run the high octane, and i guess i can buy pump gas and just add the octane boost in it???....were do i buy this at???? honda dealer???......thanks again!
    ride red, red honda,
  • HondaMXpunk
    by HondaMXpunk » Wed Feb 02, 2005 12:18 pm
    www.rockymountainmc.com
    Only place I know of. possibly local Auto Parts Dealer, they might have octane boost that can run in motorcycle, not sure.
  • CRFpride*
    by CRFpride* » Wed Feb 02, 2005 1:59 pm
    ok thanks, ill try it.
