I had removed and reinstalled the cylinder head cover thinking I could get to the valves easier for clearance check. Oops, I did not realize the rockers were on the cover so that defeated the purpose. While there, I removed the cam sprocket and chain and then reinstalled ensuring cam lobes down and sprocket hash marks aligned with casting, and ensured piston was at top dead center. The chain tensioner was replaced and set appropriately.
The problem is the cam sprocket feels like it is binding up and not turning when I manually crank. Does the cam go bad (bearings?) or possibly the chain come off the lower sprocket behind fly wheel?
Video link attached.
https://flic.kr/p/2nCjSqD
