CRF150F 2006 won’t start
  • Rowley
    by Rowley » Sat Feb 01, 2020 11:48 am
    When I try to use the kickstart, the gears won’t tighten like they use too with one or two cranks of the Kickstarter. In the past, I’d crank the kickstart slowly 2 times, felt the gears tighten a bit and then crank harder and the bike would start every time. Appreciate any feedback on what might possible be the problem or things to look into. Thanks!
    Re: CRF150F 2006 won’t start
    by Aussiecrf230 » Sat Feb 01, 2020 4:06 pm
    Hi Rowley and welcome to the site.
    Not sure what you mean by "gears tightening", but assume it means you were using the kick start to get the piston to top dead centre on compression before starting.
    Are you saying there is no felt compression anymore or just not starting?
    Have you got fuel to the carby?
    Is there spark at the spark plug when you kick it over?
Users browsing this forum: No registered users and 11 guests
