150f Clutch Problems
  • Garettluedke
    by Garettluedke » Sun Dec 09, 2018 8:53 pm
    First post
    2005 150f
    Was told when bought it needed a clutch.
    Soon taking case off I noticed there was a significant amount of play in the plates. I could tell The way it assembled was not right. The back of the inner hub had rubbbed inside the basket a bit.
    Installed new plates and pads. Installed clutch with schematics. Assembled like any other clutch out there. Obvious difference in visual compared to how it was when I got it. Put back together, kick it in gear and it stalls. Nothing. Rev it and ride it around try to warm everything up. Nothing. Adjust cable. Nothing. At a dead end.
    Re: 150f Clutch Problems
    by Aussiecrf230 » Tue Dec 11, 2018 11:53 am
    Hi welcome to the site.
    Are you saying it stalls now even with the clutch lever all the way in?
    Was there a washer behind the clutch assembly to allow it to free spin when disengaged. Not sure if it is done that way on your model bike.
  • benniejag
    by benniejag » Thu Apr 25, 2019 1:47 am
    Has anyone else had problems getting the four screws on the clutch off? if so how did you get them off?
