Changing oil
  • vetteguy
    Changing oil
    by vetteguy » Fri Dec 23, 2005 2:01 pm
    Hello all, just bought a 2003 CRF150F for my son and don't have an owners manual. I want to change the oil. What type(weight) oil and how much? Oil filter? Bike is in great shape. Anything else I should look for or check as far as maintainance goes? Thanks
    2001 XR200R
    2002 XR400
    2005 CRF230F (son)
    PGer555
    by PGer555 » Fri Dec 23, 2005 4:34 pm
    10W-40 and one quart should do the trick. These bikes dont have an oil filter, just an oil acreen that you will see when you take out the oil drain bolt. I recommend youi buy yourself a manual and possibly a service manual...
  • vetteguy
    by vetteguy » Fri Dec 23, 2005 4:49 pm
    Thank for the reply. Yes, I do plan on buying a manual. Thanks again.
    2001 XR200R
    2002 XR400
    2005 CRF230F (son)
    PGer555
    by PGer555 » Fri Dec 23, 2005 7:22 pm
    I saw your other post, try ebay, there might be a service manual on there now...
  • CrazyRF150
    Service Manual
    by CrazyRF150 » Tue Dec 27, 2005 6:05 pm
    Check out www.helminc.com for manuals
    The service manual is HIGHLY RECOMMENDED and is part # 61KPT03 (for CRF150 years 2003-2006)
    05 CRF150
    BBR Exhaust
    Renthal Drivetrain
    Dunlop D756 rubber
  • vetteguy
    by vetteguy » Tue Dec 27, 2005 6:23 pm
    Thank you.
    2001 XR200R
    2002 XR400
    2005 CRF230F (son)
  • MCSHOLDINGS
    by MCSHOLDINGS » Sun Jan 07, 2007 12:18 pm
    So I read in general CRF's have 2 drain plugs (like my XR650. Is this true? I only see the 1 with the screen. Just bought the bike used no manuals either. Seems that not quite a quart came out though leaving me to belive there is two drain plugs.
  • nedirtbikr
    by nedirtbikr » Sun Jan 07, 2007 2:40 pm
    The 230 and 150 only have one drain plug and no oil filter however, there is repository (of sorts) for the crap that comes out of the oil. The 230/150 have a centrifugal oil/crap seperator. Once a year, you should remove the reservoir, clean it, install a new seal. It's in the manual on how to do it...very easy.
    2006 CRF450R (For Sale)
