removing stock fuel screw
Posted: Sat Apr 16, 2011 2:04 pm
by ktm909
Can anybody tell me how to remove the stock fuel screw from a 2006 150f. Is there a special tool
Thanks
Chris
Posted: Mon Apr 18, 2011 7:58 am
by crf230frider
Its got a "d" shaped head on it. I have the bit that takes it out but I see that alot of people just use a wire crimp and form it into a "d" and they say it works
Posted: Mon Apr 18, 2011 11:13 am
by scotsy
And you can then replace it with an up to 05 screw with a slot in (don't lose the spring, washer and 'o' ring) or buy the extended fuel screw from the CRFSONLY shop[ :lol:
Posted: Mon Apr 18, 2011 5:08 pm
by ktm909
I have the t handle fuel screw to put in. Any ideas where I can get the wrench. I put in the power up parts but I need to do some fine tuning. Bike seems to run a lot better but has a huge flat spot when you crack the throttle wide open. Thanks for any help.
Posted: Mon Apr 18, 2011 5:09 pm
by crf230frider
If its the t handle like you get from crfs only you should be able to screw it in and tune it in by hand
Posted: Mon Apr 18, 2011 5:18 pm
by ktm909
I was looking for the d bit. Thanks for the help and quick reply. I need to remove the stock one.
Chris
Posted: Mon Apr 18, 2011 5:22 pm
by crf230frider
Ok I got ya. I got mine here at crfs only its the motion pro d shaped bit it worked good for me
Posted: Mon Apr 18, 2011 6:32 pm
by ktm909
Thanks I will look for it.
Chris
Posted: Mon Apr 18, 2011 6:39 pm
by crf230frider
No problem
