2005 CRF150f carb problem... need some advice
  • jazzguitarist
    by jazzguitarist » Sun Jun 27, 2010 8:20 am
    Greetings...
    My son's crf150f was running rough yesterday [backfiring-wouldn't rev smoothly] with choke in normal "off" position. Setting choke to half choke middle position allowed much smoother running. Spark plug had white color indicating too lean. I assumed carb needed cleaning. I removed carb - dismantled and spray cleaned everything with carb cleaner and reassembled. I was careful to put everything back in original position - including mix screw [1 3/4 turns out]. The air cut-off valve was tricky to reassemble but seemed right. But now bike will only start with choke set to midde or full choke. In middle position, will idle, but dies when throttle applied. It is ridable with full choke - so it sounds like it is starving for gas... yes? I plan to disassemble and check everything today, but any advice or shared experience with similar problem would be greatly appreciated. FYI... have been cleaning honda carbs for years - this is first time had a problem. What did I do wrong? Thanks in advance for your help!
    DT
    by Asmith » Sun Jun 27, 2010 9:24 am
    Pilot jet.
    Remove and fully clean or replace. Ideally a 45.
Users browsing this forum: No registered users and 15 guests
