new here ,im looking for a used carb
  • SEANY
    by SEANY » Wed Aug 20, 2008 9:31 am
    hi,im new here and it looks like a great site! i hate to make my first post a request but i just bought a used 03 crf150f for my son and i need a used carb for it. the float is hammered and it just keeps leaking gas a local shop(harley shop not dirtbike) had it off about 10 times and cant get it to stop,he said i should look for a replacement. thanks for any help!
    by Asmith » Wed Aug 20, 2008 9:45 am
    Welcome to the site!
    A new float or float needle would be a whole lot cheaper than a carb.
    Probably just the needle not seating.
    FLOAT Needle 16011-KCK-910 $19.98
    FLOAT 16013-KN4-A10 $18.11
  • SEANY
    by SEANY » Wed Aug 20, 2008 10:37 am
    you wouldnt happen to know the p/n specs on the stock carb. there is an aftermarket one on ebay but im not sure if it will work thanks
    by Asmith » Wed Aug 20, 2008 10:46 am
    I believe it's a 24mm Keihin PWK.
    There are knock off's of this carb, but I can't vouch for their quality. I know that the Keihin's are the best.
    http://scootrs.com/moreinfo.cfm?Product_ID=442
  • RedneckRider181
    by RedneckRider181 » Sat Aug 23, 2008 6:25 pm
    Very close...
    It's a Keihin PD,
    And I'm pretty sure it's a 24mm.
    A float pin might be needed too from the sound of things. But if everything else is okay, it would be better to just fix the old one.
    Unless you find a killer deal on ebay for a carb even better than the stock one, then you risk getting a piece of $H!+.
