stiffer suspention
    motokid54
    stiffer suspention
    by motokid54 » Sun May 29, 2005 8:55 am
    I have an '04 crf 150 and need a stiffer suspention I have been botoming out when jumpig whoops and tabletops. I hav heard that I can change the oil in my front forks or put washers in them and I think I know how to change the back but some advice wouldn't hurt.
    '04 crf 150, msr dominator bars, cyrca stealth hand shields, renthaul full dimond grips, new tires, Twin air dual stage air filter, FMF power core 4 exhaust, uncorked air box, 13,50 gearing,non-o-ring competition chain, ebc brake shoes
  • deedu
    by deedu » Sun May 29, 2005 1:00 pm
    I have the same problem with my 03 150...my shock absorber is broke and i have to get a whole new one..maybe you have the same problem..if your rear suspension is really bouncy and has no sag that is the problem most likely
    2003 CRF150
    motokid54
    by motokid54 » Sun May 29, 2005 2:40 pm
    no my problem is that i weigh to much but my short legs kept me off a 230
    by crfsonly » Sun May 29, 2005 5:34 pm
    bbr makes stiffer springs front and back and this will help significantly.
    motokid54
    by motokid54 » Mon May 30, 2005 11:11 am
    Is there any mods to tthe suspension that I can do without purchasing any aditional products. I have another question not relating to suspention read that if I pull my snorkle and baffel I need to rejett it said I should change to 98 main and 42 slow what does this mean and where can I find it thanks for the help
    by crfsonly » Mon May 30, 2005 12:41 pm
    jets are inexpensive $5 or so...removing the snorkle and getting a free flowing filter will get more air into the carb...jetting it richer will allow more fuel into the carb as well...more air/fuel bigger bang factor...bigger bang factor means more power. the jets are in the carb and are pretty quick and easy to change.
    motokid54
    by motokid54 » Mon May 30, 2005 1:24 pm
    Sorry for he misunderstanding What I meant to ask is where can I buy them I have looked in rocky mountain mc but couldnt find them does crfs only sell them and about the suspention does the washer idea work. Thanks for all the help.
  • nedirtbikr
    by nedirtbikr » Thu Jun 02, 2005 3:53 pm
    motokid54 wrote:Sorry for he misunderstanding What I meant to ask is where can I buy them I have looked in rocky mountain mc but couldnt find them does crfs only sell them and about the suspention does the washer idea work. Thanks for all the help.
    motokid -
    You can get them at any Honda dealer (assuming they're in stock.) If not, they usually take only a few days to get them in.
    motokid54
    by motokid54 » Fri Jun 03, 2005 5:09 am
    Thanks for the info I hope I can order them today. I have already found a used thrust nozzle from a kid getting rid of 150 for a two-stroke :evil: so it lookes like I can avoid shipping. Thanks for the reply
  • VDTRA 38x
    by VDTRA 38x » Fri Jun 03, 2005 6:55 pm
    For a cheap / easy fix on the front forks, I got rid of that 7 or 10 weight oil they put in there and used 30 weight hydrualic fluid. Slows both the compression and rebound. May not work well in cold weather, but I'll cross that bridge this winter.
    motokid54
    by motokid54 » Sat Jun 04, 2005 11:01 am
    Thanks for the hhelp Ill try that
  • Worldzenemies
    by Worldzenemies » Thu Jun 16, 2005 4:42 pm
    hwo did it go? i'm interested in doig thsi as well as i took a nice fall teh other night hitting our double and the front end slipping out due to the . soft suspension.
  • crfrider69
    by crfrider69 » Sat Jun 18, 2005 5:04 am
    I got a question for you guys.... is there anyway i can just ajust my rear shock up to give me a little more height and a litle bit more stifffness? if ya have any ideas i like to hear them. Thanx a lot!
    '04crf150f
    by '04crf150f » Wed Jun 22, 2005 2:01 pm
    I rode at Turkey Creek MX no long ago and had the same problem with bottomming out but on the whoops and doubles. The guy who is a co-owner of it Steve works for Pro Action and he is the only franchise in the southeast except for florida and N.C. He told me he could rebuild the suspension completely, fluid, springs, etc. But it's gonna cost $400. But, I'm gonna do it anyway so wth ya know.
    Chase Cullinan
    '04crf150f
    by '04crf150f » Sat Nov 19, 2005 6:50 am
    turns out i only had to pay 200 for the suspension rebuild
    Chase Cullinan
