DISK BRAKE LOCK!!?!?!?! need help
    MotoNinja#141
    by MotoNinja#141 » Sat Apr 30, 2005 1:14 pm
    NNNOOO...my freind didnt no and hit my front brak while my tire is off and of cours it looked up!!! How do u undo this?!!??! PLEASE HELP RIDE TOMROW!!
    05' Crf150f - FMF pipe, BBR rev box, Renthal bars grips, & chain, Stomp pad grip, ACERBIS hand gards, BR1 susppesion, PJI & Honda oils.....
  • nedirtbikr
    Re: DISK BRAKE LOCK!!?!?!?! need help
    by nedirtbikr » Sun May 01, 2005 7:38 pm
    MotoNinja#141 wrote:NNNOOO...my freind didnt no and hit my front brak while my tire is off and of cours it looked up!!! How do u undo this?!!??! PLEASE HELP RIDE TOMROW!!
    Probably too late with this...assuming you rode today...but...you can pry the disk brake pads apart with a simple standard screwdriver. HOWEVER, go slowly. Take the cover off your brake reservoir (on handlebars next to throttle.) Insert screwdriver between pads and gently apply pressure to cause them to separate. While separating the pads (using gentle, even pressure with the screwdriver) you'll see the reservoir slowly fill with fluid.
    Once seperated, install caliper and gently work front brake. Reinstall reservoir cover and you should be all set.
    Hope this helps.
