by djh65 » Mon Jun 11, 2007 1:42 pm
The adjusters will be exactly the same as when they came off. The long bolt goes through the block,the spacer, wheel, other spacer, other block and is nutted. The adjusters are set with the set bolts so they will be the same. If you need to adjust the chain make sure the notch on the adjusting blocks are the same on both sides.
David
06 HD450X made in america.
