Needle jet bushing
  • Griz
    Needle jet bushing
    by Griz » Mon Apr 18, 2005 1:47 pm
    I have read many post about replacint the jet bushing and to "put it in the right way" Just what way is the right way? I have went through 2 of these things and it is getting $$$ to keep messing it up.
    The bushing has one end that is sort of rounded and has a smaller opening as compared to the other end wich is not rounded and has a larger opening. so wich end do I insert 1st?
    PGer555
    by PGer555 » Mon Apr 18, 2005 4:24 pm
    I'm gonna save nedirtbikr some typing by telling you to go to the crf230 forum and go to the modification questions topic. There you will find a great explanation on how to install the bushing by nedirtikr. Good luck!
  • nedirtbikr
    by nedirtbikr » Wed Apr 20, 2005 11:56 am
    PGer555 wrote:I'm gonna save nedirtbikr some typing by telling you to go to the crf230 forum and go to the modification questions topic. There you will find a great explanation on how to install the bushing by nedirtikr. Good luck!
    Griz, check this thread out. It's posted in the 230 forum and the carbs are a bit different between the 230 and 150 however, the steps are basically the same.
    Narrow end of bushing goes up through the bottom of carb.
    http://crfsonly.com/forum/viewtopic.php ... c&start=15
  • Griz
    by Griz » Wed Apr 20, 2005 9:29 pm
    Thanks!
