IMPORTANT INTAKE POLL PLEASE VOTE
  • If you have taken off your snorkel on your airbox, have you ever gotten water inside the airbox?
    YES
    5
    38%
    NO
    8
    62%
    Total votes: 13
  • redrider44
    by redrider44 » Thu Feb 01, 2007 4:21 pm
    High Flyer
    by High Flyer » Sat Feb 03, 2007 2:30 pm
    It's bound too happen if you do take off the snorkel, i cant see how you would avoid not getting water in it everytime you ride.
    Witch if you do get water in it, it's not going to do your bike any good. :roll:
    2004 CRF150
    -Pro-Taper SE CR low bend
    -Michilen MS2's
    -RK MXZ3 Chain
    -Pro Taper gray waffel grips
    -Air Box cover removed
    -JT 48T Rear Sprocket
  • combatcraig58d
    by combatcraig58d » Sun Feb 04, 2007 7:10 am
    As long as you don't "submarine it", you'll be fine. I notice that dirt gets in there after washing it with my pressure washer. Just wipe it clean when you clean/inspect your air filter (hopefully pretty frequently) and it's not a big deal. It was worth the trade off to remove the snorkel and open up the box. After jetting it, it has much better throttle response and just feels better (like it's not being held back).
  • Halen
    by Halen » Sun Feb 04, 2007 8:49 am
    A few small little holes drilled in the bottom of the airbox will drain away any pooling water that is there. If water can get up to where the snorkel is.. it will go in whether there is a snorkel or not.
    Van
    09 CRF 250R
    RMR lowered suspension
    Heavily armoured for the bush
    50 tooth rear
    soft gel seat
Users browsing this forum: No registered users and 11 guests
