need help with sprockets
Posted: Sat Dec 02, 2006 3:09 pm
by dtrider4ever118
ok i got a new sprocket (51 tooth from jt) and it doesnt fit. i got the chain on and it was grinding on the chain-stay thing so i took that off but i cant get the wheel to pull back far enough to slide the axel back in and the chain does have some slack(probably right around what its supposed to have) with the wheel forward
thanks for helping
Posted: Sat Dec 02, 2006 6:24 pm
by dk54red
you need to replace the chain and measure out a new chain link. Lay them down and add the extra 3 teeth. I'm guessing three. You have a 51 and stock on a 03-05 is a 48 and would be three. Stock on a 06-07 is a 47 and would be 4 which in pretty big jump. You should always replace the sprockets (front and back) and the chain so they can wear together. You could damage your new sprocket with the old chain if its streched out bad.
Posted: Sat Dec 02, 2006 6:40 pm
by dtrider4ever118
ok my old rear sprocket is in good shape i got the bigger sprocket for some indoors races but what should i do about the chain guard thing the sprocket grinds on it should i just take it off???
and for a chain what is better for racing an oring or non oring
Posted: Sun Dec 03, 2006 6:33 am
by dtrider4ever118
ok im just gona drop a tooth on the fron sprocket and leave the stcok sprocket on the back but i still have the question about the chain oring or non-oring i know the difference but which is better for racing???
Posted: Sun Dec 03, 2006 7:07 am
by dk54red
I prefer the non 0-ring. It's more maintenance, but I feel it's worth it. Just clean it more. If you get the right size (length) chain it shouldn't grind. I like the 520 gold race chain by rk.
Posted: Sun Dec 03, 2006 2:11 pm
by dtrider4ever118
ok thanks alot for the help
