crf 230 question
  • munlin
    crf 230 question
    by munlin » Mon Dec 19, 2005 6:14 pm
    does anyone know of a good headlight unit for this bike that dosent cost an arm and a leg
    wouldnt mind a tail light but not needed
    just a light for up front
  • lilgoody05
    by lilgoody05 » Tue Dec 20, 2005 6:11 am
    I can sell you a baja headlight and wiring if you really want one. Send me a PM if your interested.
    2005 CRF 230
    *PRO CIRCUIT T-4 FULL SYSTEM EXHAUST
    *K&N AIR FILTER
    *PRO TAPER 7/8 BARS
  • Mark S
    light for 230F
    by Mark S » Fri Dec 23, 2005 11:44 am
    I actually used a headlight from my xr400, customized aluminum brackets, wired it directly to the battery with an in line fuse, and added an on/off switch right next to the crossbar. Came out looking pretty custom too!
    CRF230
    Big Gun
    BBR Rev Box
    power up kit
    BBR springs
    XR400 Headlight, YIP
  • 96bmw328ic
    by 96bmw328ic » Sat Dec 24, 2005 8:48 pm
    I had a light but it always killed my battery.
    el baja
    by el baja » Wed Jan 31, 2007 8:23 pm
    Hey, i'm getting an acerbis hhd head light,how do i wire it to my 2007crf 230f? can i wire it with a relay? or should i just run it off the battery with a fuse, i use relay all the time when i wire up ligths on my baja truck,so can i use them on my bike?
    el baja
    by el baja » Fri Feb 02, 2007 5:27 am
    Well i guess the relay idea didn't work, it will but if you forget to turn the key off it will stay on, thus draining the battery, so i just wired it to the battery with a fuse and on/off switch...
    GhostX
    Re: light for 230F
    by GhostX » Fri Feb 02, 2007 1:54 pm
    Mark S wrote:I actually used a headlight from my xr400, customized aluminum brackets, wired it directly to the battery with an in line fuse, and added an on/off switch right next to the crossbar. Came out looking pretty custom too!
    Mark S,
    Do you have photos that you can post of the XR400 light mod??
    2006 CRF230F
    See the list of Mods in My Garage:
    http://www.crfsonly.com/forum/garage.ph ... le&CID=190
