by SLC » Fri Sep 21, 2012 4:33 pm
If you haven't done a tear down on your engine, or installed a new cam etc. you don't need to do anything with it. It is "automatic" in that it's spring loaded so it keeps a steady tension on the cam chain, requiring no adjustment. Again, if you haven't had your engine apart then this reinstallation procedure isn't necessary.
