might need new rings? how hard?
  • CRF Outlaw
    by CRF Outlaw » Fri Mar 02, 2012 10:22 pm
    thinking i may need some new rings. its heard to start, less power than it used to, and smokes more than i think it should. if i were to check compression what is the normal range and what would be considered low enough that it should be rebuilt?
    if i do need to replace the rings how hard is it? so far the only work i've ever done on a 4 stroke was rejetting the carb on this bike. other than that i've only worked on single cyl 2 strokes.
  • Hondacrfrider
    by Hondacrfrider » Sat Mar 03, 2012 6:24 am
    hmmm you might need a new piston and a valve ajustment too
    Bikes in order
    -2009 crf150f (sold)
    -2008 crf230f (sold)
    -2008 crf250x (Dad's bike)(sold)
    -2008 ktm 144sx (mine, sold)
    -2009 crf100f (sister's bike)
    -2012 crf250r (mine)
    -2012 crf250r (dad's)
    by Aussiecrf230 » Sun Mar 04, 2012 3:46 am
    If you have ever replaced a top end on a 2 stroke then it won't be much harder on a 230F.
    Get the proper workshop manual and have a read then post any questions.
    Surprised it needs it though - was the aircleaner neglected?
  • CRF Outlaw
    by CRF Outlaw » Sun Mar 04, 2012 8:28 am
    it is a 2006 that i got early 2010 and looked like the filter had never been cleaned or changed. i put a twin air in it and put the power up kit in. previous owner removed the baffle but didnt rejet at all.
    by Aussiecrf230 » Mon Mar 05, 2012 3:23 am
    That combination of tardiness will result in ring wear.
    Lets hope it was overheated because of a lean condition.
    What pilot jet are you using.
  • CRF Outlaw
    by CRF Outlaw » Mon Mar 05, 2012 12:27 pm
    not sure what size it is. it was the one that came with the power up jet kit sold on the crfs only store.
