Proper Octane for 230F
  • deepcave
    by deepcave » Wed Apr 20, 2011 9:03 am
    Hey guys, I'm new here so try to take it easy on me, also sorry if this has been covered in length. I just completely rebuilt my 2005 CRF230F. I got it basically blown up and never really had any time with it. My question is I'm about to get ready for my first start up since the overhaul. I was told that I need to run 100 octane in it. Is this true and if it is what is everyones way of mixing 100 octane? Some places near me sell race fuel, however I don't believe they sell 100 octane. Only 93 octane and 110 or so.....
    any feedback would be appreciated.
    by 124 » Wed Apr 20, 2011 9:24 am
    No, it is not true. Do not run 100 octane in your bike.
    I would tell you to run at least 89-91 but the truth is that machine should basically run anything you could buy at the pump. It has no special requirements.
    General rule it to run the premium pump gas.
    by crfsonly » Wed Apr 20, 2011 9:44 am
    welcome to the group! 124 knows his stuff!
  • deepcave
    by deepcave » Wed Apr 20, 2011 2:50 pm
    thanks for the quick reply 124....i'll just stick to 91 or 93 which will be much easier and cheaper.
  • leyton
    by leyton » Wed Apr 20, 2011 11:12 pm
    124 wrote:General rule it to run the premium pump gas.
    Some can also debate the higher octane 95-96 is more refined and better quality fuel. I cant prove that.. just something I heard :/
    I always run high octane at the pump unless the manufacture states otherwise.
    by Aussiecrf230 » Thu Apr 21, 2011 5:14 am
    Using fresh fuel is just as important, as is draining the fuel bowl after washing the bike at the end of a ride day.
  • staffy24
    by staffy24 » Thu Apr 21, 2011 5:35 am
    98 is clean mostly go with that as the lesser fuels can have contaminants
    over 40 still ridin hard
    still learning
    by 124 » Thu Apr 21, 2011 7:13 am
    Absolutely, but if the subject machine is a stock 230, it isn't demanding (thermo-mechanically...yeah I made that word up ;) ) anything special. My XR80 runs fine on whatever old lawnmower gas I put it in... :D .
    Remembering your Aussie octane ratings are calculated differently than us here in the states. not sure what 98 what be equivalently...
    What Aussie said is correct. To the OP: Worry about fresh fuel, not the octane.
  • wfo4ever
    Re: Proper Octane for 230F
    by wfo4ever » Fri Jul 13, 2018 9:00 am
    I have been running 90 octane Non-Ethanol gasoline with 2 oz. of Maxima octane boost added to every gallon for my 2015 Honda CRF-230F. Is anybody else running Non-Ethanol gasoline or using octane boost? What are the opinions on running race gas and what octane/brand. I can get 110 race gas where I live, it is expensive, I have used it before on some of my 2-Stroke motocross bikes. I have used straight race gas and also have used race gas mixed 50/50 with the 90 octane Non-Ethanol gasoline for my 2-Strokers. I found it was cheaper to just use Maxima Octane Boost for trail riding and race gas for the motocross tracks. The Honda CRF-230F is a very fun and reliable motorcycle for what it is intended for and this forum has some great information and members.
    by Aussiecrf230 » Fri Jul 13, 2018 3:24 pm
    I think the non-ethanol part to be more important than boosting it above 90 MON octane rating if your engine is at stock compression. Ethanol fuels are ok and are generally a higher octane but we would need to clean out the fuel system after use. It attracts moisture which does horrible thing inside carbys and fuel strainers. I have used higher octane fuel in the past but for more a back up fuel supply for others I rode with.
    That said even quality pump fuel leaves deposits which is why we all should drain carbys and tanks if we leave it a month or more.
