Mike Coe Versus Power-Up - Results!!!
Posted: Mon Mar 22, 2010 10:48 am
For those of you still wondering whether or not to spend the time to covert from Honda's Technical Bulletin specs to Mike Coes' specs here is my take.
I initially setup my 2009 230 with the Honda-specified needle (notch #3) and 132 main jet along with a 45 pilot and removal of intake and exhaust baffles. It was much better than stock but still too lean on the bottom (forever to warm up and popping on decel) and too rich on top. I installed a 48 pilot and 125 main and was very pleased with the results.
So how did I determine that Mike’s specs are far better than Honda’s you ask?
My buddy rides a 1997 XR250 freshly rebuilt with a 32mm flat slide from XR’s Only and an FMF pipe and we also have a 2004 XR250 with 48/135 jets and all baffles removed. The 1997 was slightly stronger than the 2004 with the stock carb and noticeably stronger with the flat slide.
I weigh 150 pounds without any gear and my buddy weighs 195 pounds without any gear. With the Honda-specified jetting I could NEVER keep up with him from a stop or on the straights. Last weekend I installed the 2003-2005 needle (notch #4) with a 120 main and could instantly tell the carb was now spot on. It used to have a weird spot from ¾ to full throttle and never really pulled at the top. I just figured it was all I could expect from an old two-valve design. WRONG – It was due to bad metering and it now screams on the top end.
We went to Carolina Adventure World last weekend and lined our bikes up on the dirt dragstrip for a test. I’ve got to be honest and admit I expected the runs to be a joke but I figured I’d give it a shot just for fun. Even with the 45 less pounds who could expect a two-valve 230 to give a four-valve 250 a run for its money? I took off in first gear on the first run and he maintained a one-bike length lead the entire way but he did NOT pull away from me like he always did in the past. For the next run I used a second-gear hole-shot and kept in front by a small margin the entire length. I did the same again on the third run and kept in front again the entire length. All I can say is WOW and my buddy sure was impressed and a bit disappointed at the same time.
FYI both bikes have brand new tires and I am running 13/50 sprockets and he is running 13/50 sprockets. My 230 is bone stock except for 3/4" of fork spring spacers for 2 3/8" sag and 3 turns on the rear shock collar for 3" sag. Our top speed at the end of the dragstrip was 52 MPH. Once again, he was carrying an extra 45 pounds. I am SURE the XR would easily overtake me given enough space and distance but I really don’t care. How often do you hit 52 MPH in the woods? How about never.
On the trails the extra top end available at the top of the gears is amazing. The places where I used to shift up a gear (because it just no longer pulled hard) are now easily conquered at the top of one lower gear. These are the places where the XR250 would always gain distance on me and that is no longer the case.
If any of you have any doubts about Mike Coe’s dyno work I suggest you line up against someone running his jetting recommendations and be prepared for a wicked beating. My 230 is now like a whole new bike and I am no longer being left behind the XR250s!
Spend the money and the time and go do it!
Final results: 48 pilot with 120 main and 03-05 needle at #4 at sea level. See the chart below for variations on Mike's jetting:
Temp Mult. Pilot Main
000F 1.08 52 129
010F 1.07 51 128
020F 1.06 51 127
030F 1.04 50 125
040F 1.03 50 124
050F 1.02 49 123
060F 1.01 49 121
070F 1.00 48 120
080F 0.99 47 119
090F 0.98 47 117
100F 0.97 46 116
110F 0.96 46 115
120F 0.94 45 113
Alt. Mult. Pilot Main
0000 1.00 48 120
0500 0.99 48 119
1000 0.99 47 118
1500 0.98 47 118
2000 0.97 47 117
2500 0.97 46 116
3000 0.96 46 115
3500 0.95 46 114
4000 0.95 45 113
4500 0.94 45 113
5000 0.93 45 112
5500 0.92 44 111
6000 0.92 44 110
6500 0.91 44 109
7000 0.90 43 108
7500 0.90 43 108
8000 0.89 43 107
8500 0.88 42 106
9000 0.88 42 105
9500 0.87 42 104
000F 1.08 52 129
010F 1.07 51 128
020F 1.06 51 127
030F 1.04 50 125
040F 1.03 50 124
050F 1.02 49 123
060F 1.01 49 121
070F 1.00 48 120
080F 0.99 47 119
090F 0.98 47 117
100F 0.97 46 116
110F 0.96 46 115
120F 0.94 45 113
0000 1.00 48 120
0500 0.99 48 119
1000 0.99 47 118
1500 0.98 47 118
2000 0.97 47 117
2500 0.97 46 116
3000 0.96 46 115
3500 0.95 46 114
4000 0.95 45 113
4500 0.94 45 113
5000 0.93 45 112
5500 0.92 44 111
6000 0.92 44 110
6500 0.91 44 109
7000 0.90 43 108
7500 0.90 43 108
8000 0.89 43 107
8500 0.88 42 106
9000 0.88 42 105
9500 0.87 42 104
