Differences in exhaust
  • izcain
    by izcain » Sun Nov 02, 2008 4:07 pm
    Hello there guys. I have a 04 230 with airbox mods rejetted power up kit and baffle removed. Just wondering if anyone on here has noticed a big difference between the stock exhaust with the baffle removed and a aftermarket exhaust. I have heard that the factory exhaust with the baffle removed performs just as good and you will not notice much difference but I am curious to your guys opinion.
    Also is the twin air a better filter then the uni or are they both the same in performance? Thanks for all the help this site has been a great source of information for me. :D
    04 CRF230F
    Air box mods, power up kit, Twin air, removed baffle, BBR rear spring, Vapor computer
    97 XR100R
    Air box mods, UNI filter, opened up exhaust, rejetted, BBR 120 big bore kit, bbr cam
    NCFRC
    by NCFRC » Sat Nov 15, 2008 10:00 pm
    Don't waste your money on an expensive exhaust and the bike is way too loud with the the baffle out.
    Just modify the baffle so it can flow straight though and you'll be fine.
    I've also used and have on a Pow-Roll header pipe , better on mid to top end.
    If you relieve the back pressure too much you'll loose all your low end.
