chains and gears
    mr50
    chains and gears
    by mr50 » Mon May 07, 2007 6:16 pm
    :D if you here a clicking sound when you get on is it time to adjust one other :?: on the rear will at the nut how do you know what number to set the dial :?:
    by crfsonly » Mon May 07, 2007 6:56 pm
    where's the clicking sound coming from exactly?
    mr50
    by mr50 » Tue May 08, 2007 5:51 pm
    the sound was coming from my chain i've had the bike for about 4 months it was a brand new bike it just did it the other day when i landed a jump i always check my bike out before i ride i noticed the chain had a little more slack than the day before i loosened the rear will today and adjusted it i could tell a big difference in 2nd,3rd gear it felt like it had a lot more pull in it
    gal8x
    by gal8x » Wed May 09, 2007 8:53 am
    do you have an owners manual?
    do you have a service manual?
    you should get a service manual if you dont have one.
    Adjust your chain for about ½” of slack. A little loose is better than a little tight. Both adjusters should be on the same mark.
    If you follow the manual your chain will live a ling and happy life.
    My chain is a year old and I have plenty of room for expansion. I did install a 14 tooth primary which will absorb some slack. The chain on this bike is pretty tough. I do have some wear from the chain guide. I will try to post some pics.
