CRF 230F Jumping
    by krisrtch » Mon Apr 09, 2007 12:15 pm
    Your best bet if you wanna jump your 230 is to put a better suspension under it. That's what I ended up doing. Works Performance shock in the rear and a set of RM 250 forks up front.
  • crf100rider21
    by crf100rider21 » Mon Apr 09, 2007 3:22 pm
    I went out and tried to tighten mine up today and found that i could not get the airbox out!
    Could somone give me step by step info on how to tighten your shock?
    i was taking bolts of the side with the battery to try and get it out but it wouldnt come out
    am i trying to take to much out?
    and once i start ajusting the show how much should i tighten it?
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    protaper bark busters
    Mazda b2300
    tinted windows
    custom sound system
    flo tec with dauls commin out the back
    gal8x
    by gal8x » Mon Apr 09, 2007 5:21 pm
    I don’t know how to post pics here but I put one in my garage.
    1] Take the left side panel off.
    2] Disconnect the air boot from the back of the carburetor.
    3] There is a bolt attaching the bottom of the airbox to the frame via a clip. It is behind the frame. (see pic in my garage). I don’t remember but there may be another one under the seat. You may need WD40 on the clip; be careful not to damage the airbox. I did not need to completely remove the screw.
    4] Remove the crankcase vent hose located on the battery side of the bike.
    5] Remove the mud flap from the back of the airbox.
    6] Wiggle the airbox out. You do not need to remove the battery box.
    when ajusting the shock,
    Use a stand to get the back tire off the ground.
    A little goes a long way so test the bikes height before you button every up and ride.
  • crf100rider21
    by crf100rider21 » Mon Apr 09, 2007 5:29 pm
    thanks i will try again tomarrow
    who knows what i was doing
    lol
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
  • crf100rider21
    by crf100rider21 » Wed Apr 11, 2007 4:17 am
    thanks for the info
    i thightend it up yesterday and went for a quick ride
    no more bottoming out at least for the back
    Ben
    Honda crf230
    big gun pipe
    Power up kit
    pro taper bars
    Mazda b2300
    tinted windows
    custom sound system
    mr50
    by mr50 » Wed Apr 11, 2007 4:03 pm
    :?: do you have to loosen the shock any from the bike or can you adjust the nut on the shock with it in place :?:
  • 230forme2
    by 230forme2 » Wed Apr 11, 2007 5:39 pm
    I guess I was lucky. I was able to get to mine on the left hand side with a long punch and a hammer.
    gal8x
    by gal8x » Wed Apr 11, 2007 8:29 pm
    mr50 wrote::?: do you have to loosen the shock any from the bike or can you adjust the nut on the shock with it in place :?:
    no.
    the shock spring pushes up on the nut. using a stand will remove the weight of the bike from the spring making it easer to rotate the nut down.
    mr50
    by mr50 » Thu Apr 12, 2007 5:37 pm
    :D thanks for the info on the back shock do you have any suggestions on the front shocks ?
    gal8x
    by gal8x » Fri Apr 13, 2007 8:14 am
    mr50 wrote::D thanks for the info on the back shock do you have any suggestions on the front shocks ?
    That seems to be an open debate. Some prefer inverted forks, some modify the stock ones. I opted for a pair from a 1985 cr250. There are a lot of factors to consider.
    Just about every body agrees the front forks need help. Use the ‘Garage’ feature (hats off to CRF’s Only for that idea!) and search the 230s for mods.
    230@#)
    by 230@#) » Thu May 03, 2007 7:46 pm
    I was thinking about buying the BBR Fork Springs, I Think I read somewhere here that someone said to put only one BBR Fork spring in because with two its too stiff. I wiegh 175 Pounds do you think I will need both in. Also can someone post a step by step way to change the Fork Springs. Thanks
    satisfied
    by satisfied » Sun May 06, 2007 1:56 am
    the hawk wrote:i way about 250 and i take about 30 foot doubles and have no problem with the suspension no beefed up suspension but i did put the bbr fork springs on and it helped
    Is there a how-to on installing these? Why is it that no one in MX ever does their own work. =S
    gal8x
    by gal8x » Sun May 06, 2007 4:26 am
    230@#) wrote:I was thinking about buying the BBR Fork Springs, I Think I read somewhere here that someone said to put only one BBR Fork spring in because with two its too stiff. I wiegh 175 Pounds do you think I will need both in. Also can someone post a step by step way to change the Fork Springs. Thanks
    i have never used the springs so i cant say. i think the post you are talking about refers to a crf150f.
    i really like the bigger forks. they not only have more travel but they are set further apart on the trees. add a set of wider bars (i'm 6'2" so i can ;) ) and i can now fly over roots and wash outs. all that extra width gives me a lot more control.
  • wordtoyourmother
    by wordtoyourmother » Tue May 29, 2007 7:19 pm
    You folks are talking about spring preload, which won't affect ride height much. If you're a fatty and you crank up the preload, it'll ride a bit higher when you sit on it, but otherwise there's not much to be gained. It'll also ride like sh*t. I've jumped mine a fair bit, I cranked up the preload but then backed it off somewhere between stock and max...it handled jumps better (so long as I landed nicely) but everything else sucked. Forks are definetely a weak point, but thicker fork oil can somewhat crutch that situation.
    by Asmith » Tue May 29, 2007 9:41 pm
    wordtoyourmother wrote:You folks are talking about spring preload, which won't affect ride height much. If you're a fatty and you crank up the preload, it'll ride a bit higher when you sit on it, but otherwise there's not much to be gained. It'll also ride like sh*t. I've jumped mine a fair bit, I cranked up the preload but then backed it off somewhere between stock and max...it handled jumps better (so long as I landed nicely) but everything else sucked. Forks are definetely a weak point, but thicker fork oil can somewhat crutch that situation.
    We prefer "Gravimetrically Challenged". :lol:
