2010 CRF450R poor idle/high idle not working
  • mrwood
    by mrwood » Mon Jun 03, 2013 9:58 am
    Hey y'all,
    my 10 CRF450R started acting up this weekend- i was out mountain riding and after a while the bike would not idle by itself unless i had the high idle knob pulled out- and the adjustment seemed to have no effect on the engine speed- The bike has full Yoshi exhaust, PowerCommanderV and screenless intake.
    I hooked up the PC and checked the tps to make sure it was running 0% throttle at idle and that seemed to be in check. I also uploaded a new MAP just in case the last one somehow goofed up.
    Has anyone had issues with the high idle/idle adj, and what would resolve the problem?
    Thank you
    Cody
  • mrwood
    by mrwood » Mon Jun 03, 2013 10:01 am
    i also had the thought that the elevation change would cause the poor performance but after returning to a normal altitude it remained the same
    by Aussiecrf230 » Tue Jun 04, 2013 2:19 am
    Assume runs OK otherwise?
    Could it be running lean at idle?
    Air leak?
    Valves?
Users browsing this forum: Bing [Bot] and 7 guests
