CRF's Only Head & Valves Services
crfsonly.com :: View topic - Removing coolant, all of it.
The time now is Fri May 24, 2013 12:43 am | Log in to check your private messages
View unanswered posts | Garage
Album Register Log in
ProfileFAQSearchLog in to check your private messages
Post new topic   Reply to topic    crfsonly.com Forum Index » 450R
View previous topic | View next topic
Author Message
Dantastic
PostPosted: Wed May 02, 2012 11:41 am    Post subject: Removing coolant, all of it. Reply with quote
Hi Guys,
Im replacing my head gasket as i didnt torque it down enough when i replaced the piston. However last time i removed the coolant i managed to leave loads in the cylinder jackets and it all went into my engine.
Id rather it didnt happen again as its a ball ache and i look like a :). From my manual it just says remove lower bolt on water pump, let it drain. This is what i did previously. Do you need to lean the bike over, squeeze the hoses etc?
Also if there is anything else i need to know when replacing the head gasket please shout up.
Thanks
Dan
View user's profile Dantastic's Garage Send private message
Back to top
riddler9
2009 Honda CRF250X
PostPosted: Wed May 02, 2012 11:48 am    Post subject: Reply with quote
Removing the radiator cap and doing the slow side-to-side lean gets most of it. You may still have a little trapped, it really comes down to air pockets.
View user's profile riddler9's Garage Send private message
Back to top
Dantastic
PostPosted: Wed May 02, 2012 1:17 pm    Post subject: Reply with quote
Cheers. Does squeezing the hoses help or not? Is it just a case of doing the best you can to get as much as you can out?
Back to top
riddler9
2009 Honda CRF250X
PostPosted: Wed May 02, 2012 1:26 pm    Post subject: Reply with quote
I personally don't see that helping much, but its worth a shot a guess Confused
Water flows through the pump, and the pump separates the pressure. If you take the hose off the pump then you will only be draining the one side. Similarly, squeezing the hose on that side will just push water in the path of least resistance, which is the radiator.
You’re really trying to get the water out of the motor, which is being inhibited by the pump. If you drain everything from the radiators, pull the hoses, and then leave the drain bolt open an rock the bike every few minutes you should get a good result
Short of pulling the pump, I am not sure what else would help. Maybe shop vac the coolant from the hose Laughing
Back to top
Back2-2
PostPosted: Wed May 02, 2012 4:59 pm    Post subject: Reply with quote
I used the compressor and lightly hit it with air to push all the remnants of coolant out of the system. Short controlled blasts at the cap port.
View user's profile Back2-2's Garage Send private message
Back to top
riddler9
2009 Honda CRF250X
PostPosted: Thu May 03, 2012 6:32 am    Post subject: Reply with quote
Brave! It does not take much air pressure to blow a pin hole at the tank joint in the stock radiators. I take it you did not try to seal off the air?
Back to top
Back2-2
PostPosted: Thu May 03, 2012 6:52 am    Post subject: Reply with quote
No - it is just flow air. Very little pressure. Gets all the little pockets of coolant out.
Back to top
Dantastic
PostPosted: Thu May 03, 2012 8:29 am    Post subject: Reply with quote
I think ill go with the slow shake side to side. Thanks fellas!
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Trail Tech Voyager
Powered by phpBB © 2001, 2002 phpBB Group
Theme created OMI of Kyomii Designs for BRIX-CENTRAL.tk.
