| Author |
Message |
sareljr
2003 Honda CRF150F
Posted: Mon Nov 01, 2010 1:50 pm Post subject: Starting cold |
| I have an '03 150f and was wondering how to start it easier |
Back to top |
honda230guy
2008 Honda CRF230F
Posted: Mon Nov 01, 2010 2:35 pm Post subject: hey |
| fully choke it pump the throttle a few times and start it. |
Back to top |
AgentSmith
Joined: 10 Apr 2006 Posts: 14869 Location: In the Matrix...Waiting for an Exit.
Posted: Mon Nov 01, 2010 2:37 pm Post subject: Re: hey |
| honda230guy wrote: |
No need to pump the throttle...no accelerator pump.  |
Back to top |
dsrpilot
Joined: 30 Sep 2009 Posts: 243 Location: Pittsburgh, PA
Posted: Mon Nov 01, 2010 5:21 pm Post subject: Re: Starting cold |
| sareljr wrote: |
Assuming your bike is in good mechanical shape overall...
Have you done any jetting work yet?
Fuel screw and power-up kit will help if you've not yet done it.
Can get it right here at CRFs only: http://www.crfsonly.com/catalog/product_info.php/cPath/28_71/products_id/3201
Recommend the fuel screw also.
It made a great difference in both our 150f and 230f.
Be sure to clean the carb while you're in there. |
Back to top |
sareljr
2003 Honda CRF150F
Posted: Tue Nov 02, 2010 12:29 pm Post subject: |
| My bike is in mint condition,bone stock,and we have not done anything to it, and what would the power up kit or the needle help? |
Back to top |
dsrpilot
Posted: Tue Nov 02, 2010 2:02 pm Post subject: |
| sareljr wrote: |
So if it's in mint condition has it always been hard to start when cold or has something changed lately? Have you had it since new?
Honda's are very lean and 'cold blooded' from the factory. The bigger jets will help richen the fuel mixture up and should make it easier to start and warm up when cold.
The power-up needle, along with the jets will give your bike a little more power if you open up the airbox and exhaust a little as well.
Here are a couple of links to get you started.
http://www.crfsonly.com/forum/viewtopic.php?t=13787
http://www.crfsonly.com/forum/viewtopic.php?t=31245&highlight=
Good luck... |
Back to top |
sareljr
2003 Honda CRF150F
Posted: Wed Nov 03, 2010 11:43 am Post subject: |
| its been sitting for a while I think hondas shouldn't sit and should be ridin, I think mine is just hard to start because I havnt ridin it in a while |
Back to top |
dsrpilot
Posted: Wed Nov 03, 2010 2:38 pm Post subject: |
| sareljr wrote: |
Did it sit with gas in the carb?
That would be the problem. Dump/drain the gas out of the tank. Take the carb off and clean it.
Clean or replace the pilot and main jets. You can also use a gas additive to help clean it. I like Sea Foam. You still need to clean the carb manually.
This happens to all bikes, not just Honda. The gas gets old and creates a varnish on the metal pieces that makes the carb not move the fuel like it was designed to do.
If you're not going to ride it for a few weeks, turn the gas off and let the bike idle until it stops. Open the drain on the bottom of the bowl and let the last drops come out of the carb. Put a fuel stabilizer in the tank (Sea Foam does this also).
I suspect this will fix u up...
Good luck. |
Back to top |
Cushman
Joined: 26 Jan 2007 Posts: 17 Location: Hudson / Tampa, FL
Posted: Tue Feb 15, 2011 7:21 pm Post subject: |
| Our CRF100 with exhaust started very easily, when we got the stock 150 it was very hard. It was much easier after a jet change and taking out the center exhaust part also added power. |
Back to top |
crfsonly Owner
2005 Honda CRF450X
Back to top |
