GoPro Hero HD Video Cameras and Accessories.
crfsonly.com :: View topic - WI'm at is the Tensioner stopper tool
The time now is Thu Jan 19, 2017 12:38 am | Log in to check your private messages
View unanswered posts | Garage
Album Register Log in
ProfileFAQSearchLog in to check your private messages
Post new topic   Reply to topic    crfsonly.com Forum Index » General Maintenance
View previous topic | View next topic
Author Message
detox
PostPosted: Sat Jan 05, 2008 1:01 pm    Post subject: WI'm at is the Tensioner stopper tool Reply with quote
Trying to do my first valve adjust on my 06 450x and the owners manual says I need the Tensioner Stopper 070mg-0010100. The thing costs $73 from the local dealer. Is it needed? Some sort of work around?
Are there any other hang ups I'm likely to run into?
Thanks
View user's profile detox's Garage Send private message
Back to top
madmax
PostPosted: Sat Jan 05, 2008 2:02 pm    Post subject: Reply with quote
No, use a small screwdriver. Just stick it in and turn to the right.
The way i do it is take it off. Remove the small screw where the tool (screwdriver) goes in, then remove the two bolts that hold it to the cyclinder.
When replacing, just put the screwdriver in and turn to the right. Now hold screwdriver and bolt it back to the cyclinder, then just let go of the screwdriver. It will turn back to the left by itself.
By taking it off you won`t have to worry about it tighting the chain while you have the cam gear off.
View user's profile madmax's Garage Send private message
Back to top
madmax
PostPosted: Sat Jan 05, 2008 2:10 pm    Post subject: Reply with quote
Other things to remember is to cover the cam tower with a rag, you don`t want to drop a shim down there. And make sure your cam lobes are not facing down against the buckets when you tighten the cam assembly back down, this will force the valves into the piston. Just point them up to be safe.
Back to top
detox
PostPosted: Sat Jan 05, 2008 3:00 pm    Post subject: Reply with quote
Thanks, that helps. Now I need to figure out the correct shim size. I think I know how.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
Page 1 of 1
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB 2001, 2002 phpBB Group
Theme created OMI of Kyomii Designs for BRIX-CENTRAL.tk.
