Suspension Database
    Suspension Database
    by crfsonly » Thu Apr 12, 2007 6:28 am
    Please keep other info out of this thread. Only answer the questions. Copy and paste to keep format uniform.
    Note: Clicker adjustment should be expressed in clicks from full hard.
    Year:
    Rider Weight:
    Rider Weight with Gear:
    Riding Style (i.e. Desert, MX):
    Forks Raised in Triples:
    Rear Tire Size:
    Aftermarket Triples/Offset:
    Fork Springs Wt:
    Fork Spring Brand:
    Fork Oil Amount:
    Fork Oil Brand & Weight:
    Fork Compression:
    Fork Rebound:
    Fork Valving:
    Shock Spring Wt:
    Shock Spring Brand:
    Shock Hi speed Compression:
    Shock Lo speed Compression:
    Shock Rebound:
    Shock Valving:
    Shock Oil:
    Race Sag:
    Preload:
  • gj2slick
    by gj2slick » Thu Apr 12, 2007 7:58 pm
    Year: 2005
    Rider Weight: 155
    Rider Weight with Gear: 165
    Riding Style (i.e. Desert, MX): Desert/offroad
    Forks Raised in Triples: 3mm
    Rear Tire Size:110/100-18
    Aftermarket Triples/Offset: Applied-22mm
    Fork Springs Wt: .47-fork/1.6 pressure
    Fork Spring Brand: Eibach
    Fork Oil Amount: 375ml fork/192ml chamber
    Fork Oil Brand & Weight: Torco RFF 7W
    Fork Compression: 7
    Fork Rebound:11
    Shock Spring Wt: 5.5kg
    Shock Spring Brand: Oem
    Shock Hi speed Compression:1 1/2
    Shock Lo speed Compression:4
    Shock Rebound:10
    Shock Valving: ~
    Shock Oil: Torco RSF Medium
    Race Sag: 96mm
    Preload: n/a
  • 450x addiction
    by 450x addiction » Sat Jun 23, 2007 7:12 pm
    I just ordered a oem service manual...will I be able to set my bike to my 250 butt?
    I have been a Heavy equipment mechanic for 20 plus years...but dont know crap about bikes yet.
    bought my bike in april...hadnt ridden for 25 years
    by Asmith » Sat Jun 23, 2007 7:20 pm
    450x addiction wrote:I just ordered a oem service manual...will I be able to set my bike to my 250 butt?
    You will need to get new springs for your 250 lb butt. :shock:
    As far as mechanics skills are concerned, you should have no issues. If you can rebuild hydraulic pumps and pressure compensators, bikes are a piece of cake...
  • 450x addiction
    by 450x addiction » Sat Jun 23, 2007 7:33 pm
    do I need springs for front and back and what kind, size ect... and were should I get them
    by Asmith » Sat Jun 23, 2007 7:51 pm
    450x addiction wrote:do I need springs for front and back and what kind, size ect... and were should I get them
    Stock Spring Rates:
    Fork: 0.46 kg/mm
    Shock: 5.3 kg/mm
    Recommended Spring Rates:
    Fork: 0.51 kg/mm
    Shock: 5.9 kg/mm
    You can get them right here at CRF's Only.
    $ 95 for the front springs, $ 105 for the rear.
    And yes only the 05 R can will fit the X model.
  • 450x addiction
    by 450x addiction » Sat Jun 23, 2007 7:59 pm
    I take it the manual I have ordered will walk me through the r&r ???
    by Asmith » Sat Jun 23, 2007 8:18 pm
    450x addiction wrote:I take it the manual I have ordered will walk me through the r&r ???
    Yup. Either the Clymer or the factory Honda will walk you through it. If you have any issues just post them up and someone will be right along to help.
    kena48
    by kena48 » Sat Aug 16, 2008 8:15 pm
    Year: 2007
    Rider Weight: 200
    Rider Weight with Gear: 220
    Riding Style (i.e. Desert, MX): Mix Mud/Sand/Hard
    Forks Raised in Triples: NA
    Rear Tire Size: Stock
    Aftermarket Triples/Offset: NA
    Fork Springs Wt: Stock
    Fork Spring Brand: NA
    Fork Oil Amount: Stock
    Fork Oil Brand & Weight: Stock
    Fork Compression: 18
    Fork Rebound: 12
    Fork Valving: Stock
    Shock Spring Wt: Stock
    Shock Spring Brand: Stock
    Shock Hi speed Compression: 1&3/4
    Shock Lo speed Compression: 15
    Shock Rebound: 16
    Shock Valving: Stock
    Shock Oil: Stock
    Race Sag: 3.9
    Preload: .50
    2007 CRF450X; JD Kit, Airbox & Sides, Smog, Exhaust
    http://picasaweb.google.com/kena48/Motorcycle
    Richd1963
    by Richd1963 » Thu Nov 19, 2009 4:47 am
    Year: 2005
    Rider Weight: 230lbs
    Rider Weight with Gear: 237
    Riding Style (i.e. Desert, MX): Single track trails.
    Forks Raised in Triples: Stock
    Aftermarket Triples/Offset: Stock
    Fork Spring Brand: Stock
    Fork Compression: Stock
    Fork Rebound: Stock
    Fork Valving: Stock
    Shock Hi speed Compression: Stock
    Shock Lo speed Compression: Stock
    Shock Rebound: Stock
    Shock Oil: Stock
    Race Sag: Cannot obtain proper Sag
    Preload:Stock
    I have not been able to attain the proper race sag after setting up the static sag. I believe I need a stiffer rear spring, but I am not sure what spring rate to order? Bike rides rigid, front and rear! Any hepl will be appreciated. I live in So. Cal. I can either replace the spring myself, or take bike to shop for complete suspension work up? Pros and cons? Thanks!
    Richard
    05' CRF45X
    08' XR650L
    02' ZRX1200
    Semper fi
    by Asmith » Thu Nov 19, 2009 7:05 am
    Richd1963 wrote:I have not been able to attain the proper race sag after setting up the static sag. I believe I need a stiffer rear spring, but I am not sure what spring rate to order? Bike rides rigid, front and rear! Any help will be appreciated. I live in So. Cal. I can either replace the spring myself, or take bike to shop for complete suspension work up? Pros and cons? Thanks!
    Your bike rides rigidly because your springs are way too soft.
    I know that's hard to understand, but here's why. The damping rates are progressive, which means the farther into the stroke, the harder the damping becomes. The top of the stroke should be comfortable and it should get more rigid as you go down. Since your springs are too soft for your weight, you are not at the top of the stroke under normal riding. You are already into a more harsh section of the valving.
    The rear spring should be either a 5.7kg/mm or a 5.9kg/mm. Your weight has you in the middle. You can use either, the lighter spring will need more preload, the heavier, less.
    The front forks will need .49kg/mm springs.
    Having the suspension revalved for the type of riding you do will make a world of difference and you will fall in love with your bike all over again.
    elmo450x
    by elmo450x » Thu Nov 19, 2009 7:22 am
    Year: 2007
    Rider Weight: 210
    Rider Weight with Gear: 220-230
    Riding Style (i.e. Desert, MX): desert
    Forks Raised in Triples: no
    Rear Tire Size: 120/100/18
    Aftermarket Triples/Offset: stock/ 24mm
    Fork Springs Wt: .49kg
    Fork Spring Brand: racetech
    Fork Oil Amount:375 ml.
    Fork Oil Brand & Weight: Torco RFF 5wt
    Fork Compression: 10
    Fork Rebound: 13
    Shock Spring Wt: 5.7kg
    Shock Spring Brand: race tech
    Shock Hi speed Compression: stock
    Shock Lo speed Compression: 1 click in from stock
    Shock Rebound: 5 clicks slow from stock
    Shock Valving: stock (until next week, right Paul?)
    Shock Oil: stock fish oil
    Race Sag: 97mm
    Preload: ?
    "Life moves pretty fast. If you don't stop and look around once in a while, you could miss it." — Ferris Bueller
  • 450X4ME
    by 450X4ME » Mon Feb 03, 2014 11:46 am
    Where did everbodys suspension post go?
