--- Join Us On Facebook ---
crfsonly.com :: View topic - 450x suspension question
The time now is Thu May 23, 2013 7:28 pm | Log in to check your private messages
Album Register Log in
Post new topic   Reply to topic    crfsonly.com Forum Index » 450X
Author Message
Bholt87
PostPosted: Thu Apr 12, 2012 9:01 pm    Post subject: 450x suspension question Reply with quote
So currently I have Factory connection springs in the forks (.52 kg) and fc spring in the rear (6.3 kg). Still have stock valving and stock shim stack in the forks. I'm around 300lbs. I currently ride a lot of trails and tend to ride the track couple times a month. I've ridden my buddies 450r on the track and the suspension seems to handle it so much better. Was wondering if anyone has used race tech gold valves and shims? Or if someone has some ideas or other solutions.
View user's profile Bholt87's Garage Send private message
Back to top
Lars450X
PostPosted: Sun Apr 15, 2012 8:58 pm    Post subject: Reply with quote
Two different styles of styles of suspension designs as far as Spring seats and range of motion for types of terrain, where as the X wants to use a lot of travel over moderate terrain with small jumps here and there, and the R is capable of jumping Huge ramps and use its full travel when launching and landing with huge G loads each time, so the Spring seats are designed to meter flow along with valving to maintain a mid level fork and shock float, where as the X will use much more travel over very small hits and the R will not move, and rides faster and more controllable over bumps, yet lighter and slower riders feel the R suspension as being harsh, and the X as more plush over bumps comparatively. The science to suspension is wide and the Guys at many shops have really got the suspension dialed if you truly want to figure out a setup you like, your R can be made to feel like that R if that's what you want, It takes you knowing what you desire in ride feel and knowing what a factory R rides like can be put into your X and produce nearly that same feel, myself I went full factory connection and couldn't be happier, yet and many have said that about many others too, it's all about what you want and how much your willing to spend.
Have you ever changed seals and fluid on your forks?
There are ways to make your bike do what you want..
View user's profile Lars450X's Garage Send private message
Back to top
Krannie
2005 Honda 2005 CRF450X
PostPosted: Thu Apr 19, 2012 9:20 pm    Post subject: Reply with quote
You need to re-shim.
You need stiffer springs too.
.52/6.3 is about right for 265 naked.
If you are 300 before riding gear, you should be looking at .56/6.5.
When you and stiffer springs, you effectively remove the rebound damping, because it now is working against a much stiffer load.
Re-valving the shim stack will alow you to run stiffer settings without adding harshness.
View user's profile Krannie's Garage Send private message Send e-mail Visit poster's website
Back to top
Display posts from previous:
Jump to:
Trail Tech Voyager
