Trail Tech Voyager
crfsonly.com :: View topic - Water pump seal removal
The time now is Thu May 23, 2013 4:02 am | Log in to check your private messages
Album Register Log in
Post new topic   Reply to topic    crfsonly.com Forum Index » 450R
Author Message
YucTown44
2004 Honda CRF450R
PostPosted: Tue Mar 27, 2012 2:22 pm    Post subject: Water pump seal removal Reply with quote
How do I take out the water pump seal on my 04 CRF450R?
View user's profile YucTown44's Garage Send private message
Back to top
lightflight
2005 Honda CRF450R
PostPosted: Tue Mar 27, 2012 2:28 pm    Post subject: Reply with quote
Here is a how to with pics.
http://crfsonly.com/howto/450r/water-pump/honda-crf450r-water-pump-rebuild.php
View user's profile lightflight's Garage Send private message
Back to top
lightflight
2005 Honda CRF450R
PostPosted: Tue Mar 27, 2012 2:31 pm    Post subject: Reply with quote
Also water pump rebuild kit if needed.
http://www.crfsonly.com/catalog/product_info.php/products_id/3651
If you are just replacing the seals and find that the shaft is worn make sure you replace it otherwise you will need new seals again soon.
Back to top
YucTown44
2004 Honda CRF450R
PostPosted: Tue Mar 27, 2012 2:41 pm    Post subject: Reply with quote
Alright thanks! It was just rebuilt a yr ago, but it seems to be overheating more and more frequently. Mostly on rides where we're doing slow climbing stuff with rhinos
Back to top
YucTown44
2004 Honda CRF450R
PostPosted: Tue Mar 27, 2012 3:00 pm    Post subject: Reply with quote
I just let it run til it overheat... Nothing came out of the weep hole. So the seals are good right? What does this mean?
Back to top
Back2-2
PostPosted: Tue Mar 27, 2012 6:30 pm    Post subject: Reply with quote
If you are not getting wetness out of the weep hole the ceramic disc / seal is good. If your radiator fluid is not going down and trans fluid going up the inner oil seal is good.
It sounds like you are not getting enough air flow to keep cool due to the slower speeds.
My riding Buddy talks highly of the water wetter type products. Don't remember which one he uses ?
He swears it's the real-deal - Might give that a try.
View user's profile Back2-2's Garage Send private message
Back to top
YucTown44
2004 Honda CRF450R
PostPosted: Tue Mar 27, 2012 7:02 pm    Post subject: Reply with quote
Alright thanks I'll give it a try. Its definitely fine when I'm riding at high speeds, but I've got a race coming up and don't want to chance it
Back to top
RLPII
2005 Honda CRF450X
PostPosted: Tue Mar 27, 2012 7:43 pm    Post subject: Reply with quote
Engine Ice works for my 05 450X, since changing it, has never overheated.
Hope this helps....
View user's profile RLPII's Garage Send private message
Back to top
YucTown44
2004 Honda CRF450R
PostPosted: Wed Mar 28, 2012 9:33 am    Post subject: Reply with quote
Ya used to use engine ice, but when I had my water pump rebuilt the guy put maxima coolanol in it. I just talked to my buddies mechanic and he suggested ziptie because thats what they use in their race bikes. As well as switching to a 1.88 rad cap.
Back to top
fbr
2007 Honda CRF250R
PostPosted: Sat Dec 15, 2012 5:51 pm    Post subject: Reply with quote
After removing the seal on the impeller side, I can see that the bore between the two seals is not concentric. There is a longer radius near the weep hole giving the bore a shape like a cam lobe on a cam shaft. Is this machined OEM or wear and tear?[/img]
View user's profile fbr's Garage Send private message
Back to top
Back2-2
PostPosted: Sun Dec 16, 2012 5:58 am    Post subject: Reply with quote
If I understand you correctly - you are describing the hole in the case remaining after the seals & pump shaft have been removed from the side case. That is just the OEM hole for the shaft to go through. The seals take care of centering the shaft and the hole in the case is a backing / shelf for the inner seal surface to seat on.
It is a cast aluminum part, the hole is not required to be perfect. the shaft does not touch any of the surface of hte hole. I would not think it would be grossly out of round ? The inner seats where the seal rides should apear to be milled nice and flat.
Hope that helps ?
Back to top
Display posts from previous:
Jump to:
Trail Tech Voyager
