CRF's Only Head & Valves Services
crfsonly.com :: View topic - Valve clearance different after rebuild?
The time now is Wed Jun 19, 2013 4:54 am | Log in to check your private messages
Album Register Log in
Post new topic   Reply to topic    crfsonly.com Forum Index » General Maintenance
Author Message
Dantastic
PostPosted: Sat Feb 25, 2012 8:08 am    Post subject: Valve clearance different after rebuild? Reply with quote
Hi guys,
I am changing my piston, got my piston all in ok but went to double check the valve clearances and the right inlet valve has 0 clearance. All the others are fine. Any ideas?
Bikes 04 ish CRF450.
Thanks
Dan
View user's profile Dantastic's Garage Send private message
Back to top
dirtae
PostPosted: Sat Feb 25, 2012 9:14 am    Post subject: Reply with quote
Did you check what the clearance was before the rebuild? If you did and before the rebuild they were fine, is it possible you got your shims mixed up?
View user's profile dirtae's Garage Send private message
Back to top
Dantastic
PostPosted: Sat Feb 25, 2012 9:57 am    Post subject: Reply with quote
Yeh they were ok. Sarting to think that maybe ive got the cam in the wrong position. When its at TDC, the cam faces backwards. Is that just after the de comp lever or before? When you have the cam off it turns freely then just activates the de comp then normal again. When getting the cam back on, bikes at TDC, is cam before the de comp activation or after?
Back to top
2005 Honda CRF450X
PostPosted: Sat Feb 25, 2012 10:08 am    Post subject: Reply with quote
use the TDC markers on the cam sprocket and crankshaft punch marks with cam lobes facing to the rear to find TDC. as mentioned it's either the shims were mixed up or you aren't at TDC.
View user's profile crfsonly's Garage Send private message Visit poster's website
Back to top
Dantastic
PostPosted: Sat Feb 25, 2012 4:09 pm    Post subject: Reply with quote
It wasnt at TDC. Apparently ive got 2 marks on the cog you check! Thanks.
Back to top
Display posts from previous:
Jump to:
--- Join Us On Facebook ---
