--- Join Us On Facebook ---
crfsonly.com :: View topic - Mike Coe Versus Power-Up - Results!!!
The time now is Thu May 23, 2013 5:23 pm | Log in to check your private messages
Album Register Log in
Goto page Previous  1, 2, 3  Next
Post new topic   Reply to topic    crfsonly.com Forum Index » 230F
Author Message
dsrpilot
PostPosted: Tue Mar 23, 2010 5:06 am    Post subject: Reply with quote
Could you expand the headings here...
What is Mult.?
Temp Mult. Pilot Main
000F 1.08 52 129
Alt. Mult. Pilot Main
0000 1.00 48 120
View user's profile dsrpilot's Garage Send private message
Back to top
VortecCPI
2009 Honda CRF230F
PostPosted: Tue Mar 23, 2010 1:49 pm    Post subject: Reply with quote
What is Mult.?
000F 1.08 52 129
0000 1.00 48 120
Temperature(F) - Multiplier - Pilot Jet - Main Jet
Altitude(Feet) - Multiplier - Pilot Jet - Main Jet
These are multipliers used to yield adjustments for a given temperature (deg F) and/or altitude (feet) from the baseline Mike Coe jetting specs.
View user's profile VortecCPI's Garage Send private message
Back to top
booda
PostPosted: Mon Apr 26, 2010 5:00 pm    Post subject: Reply with quote
stupid question you say #4 is that counting up or down
View user's profile booda's Garage Send private message
Back to top
ylagarde27
PostPosted: Fri Oct 15, 2010 7:11 am    Post subject: Reply with quote
VortecCPI wrote:
What is Mult.?
000F 1.08 52 129
0000 1.00 48 120
What should i put if i obtain
temp - 1.00 - 48 - 120
alt - .99 - 48 - 119
Im running between 118-1300 ft and 50-90F!
Thanks!!!
View user's profile ylagarde27's Garage Send private message Send e-mail
Back to top
VortecCPI
2009 Honda CRF230F
PostPosted: Tue Oct 19, 2010 4:03 am    Post subject: Reply with quote
GRAFREAK wrote:
VortecCPI wrote:
What is Mult.?
000F 1.08 52 129
0000 1.00 48 120
Thanks!!!
Go with the 120 main and start with a 45 pilot. If you still have popping on deceleration with the mixture screw 2-1/2 turns out install a 48 pilot. Chances are you'll be just fine with the 45 pilot. Mine needed a 48 and Mike Coe said only a few he did required a 48.
Good Luck...
Back to top
mdtoney
PostPosted: Mon Dec 20, 2010 1:30 pm    Post subject: Reply with quote
My wife bought her 230 ('04 w/ BBR pipe, snorkel removed) with the Power Up kit. It ran good but I swapped to the '03-'05 needle, 48p, 120m, and it runs even better. Starts easily, warms up quickly, and runs strong from idle to redline. We ride from sea level to ~1500 ft, in 40-80 degree temps.
An occasional fuel screw adjustment is all she needs.
View user's profile mdtoney's Garage Send private message
Back to top
ylagarde27
PostPosted: Thu Jan 13, 2011 10:28 am    Post subject: Reply with quote
VortecCPI wrote:
GRAFREAK wrote:
VortecCPI wrote:
What is Mult.?
000F 1.08 52 129
0000 1.00 48 120
Thanks!!!
Good Luck...
What about the float???
Back to top
VortecCPI
2009 Honda CRF230F
PostPosted: Tue Jan 18, 2011 5:24 pm    Post subject: Reply with quote
GRAFREAK wrote:
VortecCPI wrote:
GRAFREAK wrote:
VortecCPI wrote:
What is Mult.?
000F 1.08 52 129
0000 1.00 48 120
Thanks!!!
Good Luck...
Float setting is 1/2 inch.
Back to top
JohnSBA
2006 Honda CRF250X
PostPosted: Tue May 10, 2011 6:05 pm    Post subject: Reply with quote
I've been running the power-up jetting for the last 2 years on an -06 CRF230F (45 pilot, 132 main, power-up needle in middle clip position, twin-air filter, intake snorkle and exhaust baffle removed), and like everyone else, I agree its way better than stock. Small annoyances with this setup are: it still is cold-blooded, , it has decel pop, and its tends to flatten from 3/4 to full throttle.
I decided to try this Mike Coe setup to compare.
EDIT: Whole bunch of trail/error removed... see my later post.
View user's profile JohnSBA's Garage Send private message Visit poster's website
Back to top
2005 Honda CRF450X
PostPosted: Tue May 10, 2011 6:21 pm    Post subject: Reply with quote
john...have you tried the power up kit with a 48 pilot and the 135 main? that would likely help the starting and idle and likely help the top end stumble. our power up kit comes with the 45, 132 and the 135. i'll be interested in your experience with the 48.
View user's profile crfsonly's Garage Send private message Visit poster's website
Back to top
JohnSBA
2006 Honda CRF250X
PostPosted: Tue May 10, 2011 6:36 pm    Post subject: Reply with quote
I don't think I have a 135 main on hand, but I've got a 132. I'll try the 48/132/power-up needle combo tonight and report back, and I can get a 135 tomorrow and share that comparo as well.
Edit: ok, put that combo in the bike, start up fine, idle good, 1/2 throttle it started to stumble with the clip in the middle position. I'll try combos of clip positions and a 135 main and report back...
At least I've become expert at removing the carb and re-installing Very Happy
Back to top
JohnSBA
2006 Honda CRF250X
PostPosted: Sun Jun 12, 2011 11:19 am    Post subject: Reply with quote
OK, SUCCESS! Turns out, all the problems I've been having with my different carb setup's was due to a plugged emulsion tube, once I cleaned that, everything started making sense and I started to get results similar to everyone else.
Conclusion: I'm sold on the Coe jetting setup. Bike runs very good through the entire rev range now. The power-up settings are way better than stock but I had dead spots after 1/2 throttle that I just couldn't solve. The coe setup has no dead spots and pulls very hard right to the top. No decel pop, starts easy of choke. My setup is now:
Elevation: Sea level, temp 70deg F
45 pilot
120 main
03-05 needle in clip position #4
Pilot screw out 1.5 turns
Back to top
Itrack
PostPosted: Thu May 24, 2012 8:42 am    Post subject: Reply with quote
I ordered the following yesterday.
45 pilot
120 main
03-05 needle
Looking forward to the results. The local dealer wanted $36 for the factory Honda needle so I found a vendor online and ordered all three for $30 shipped. Can't wait to try this out as I'm at sea level and my top end is really weak. Is Mike Coe on this board? I'd really like to read up on any of his posts regarding tuning of these bikes.
View user's profile Itrack's Garage Send private message
Back to top
PatrickMcCabe
2006 Honda CRF230F
PostPosted: Tue Jun 12, 2012 5:19 pm    Post subject: Reply with quote
I was only really able to take it up and down the alley here in Chicago. But like everyone else was a wonderful setup to add to my bike. I will order the parts for the wifes bike this week. Great Mod thanks guys!
View user's profile PatrickMcCabe's Garage Send private message
Back to top
PatrickMcCabe
2006 Honda CRF230F
PostPosted: Thu Nov 01, 2012 5:00 pm    Post subject: Reply with quote
my set up
45 pilot
120 main
03-05 needle in clip position #3
Pilot screw out 2.5 turns
(sidenote:carb tuning on the kennedy during rush hour is hilarious)
The bike did not enjoy the needle in the fourth position,
nor did it care for the baffles in place. there is power
all over the rev range, nice and smooth delivery, neighbor
was eveimpressed how "quiet" it is. Thanks to everyone!
Back to top
Display posts from previous:
Page 2 of 3
Jump to:
Page 2 of 3
