crfsonly.com :: View topic - Clutch wont disengage
The time now is Fri Nov 20, 2009 5:16 pm | Log in to check your private messages
Album Register Log in
Post new topic   Reply to topic    crfsonly.com Forum Index » General Maintenance
Author Message
rrmiller32
PostPosted: Thu Nov 05, 2009 6:41 pm    Post subject: Clutch wont disengage Reply with quote
I have an 02 crf450. The clutch won't completely disengage when I pull in the lever. Basically my bike won't idle when the clutch is pulled in. I have put it up on a stand and clicked down into first gear and the back tire starts spinning pretty fast. Is there something wrong with the clutch or maybe just the clutch cable?
View user's profile rrmiller32's Garage Send private message
Back to top
marks crf
PostPosted: Thu Nov 05, 2009 8:46 pm    Post subject: Reply with quote
sounds like you need new clutch internals like basket,plates and fibres
my #00
"it doesn't matter who wins or loses than why do they keep a score"
View user's profile marks crf's Garage Send private message
Back to top
rrmiller32
PostPosted: Thu Nov 05, 2009 8:53 pm    Post subject: Reply with quote
What should I be looking for to see if it needs replacement?
What are fibres? Would I need new springs too?
Back to top
marks crf
PostPosted: Fri Nov 06, 2009 12:34 pm    Post subject: Reply with quote
look for burnt or warped steel plates, sharp groves in the basket, and dead looking fibre clutch plates.
if the basket is good you can get away with buying a clutch kit which will have all the clutch plates, steels and fibres and new springs
my #00
Back to top
marks crf
PostPosted: Fri Nov 06, 2009 12:43 pm    Post subject: Reply with quote
check out the crfsonly parts for a crf450r
and you'll find clutch kits, baskets etc
my #00
Back to top
rrmiller32
PostPosted: Mon Nov 16, 2009 9:55 am    Post subject: Reply with quote
So took apart the clutch and checked things out. All the plates look good. I did notice some grooves in both the outer basket and the inner hub, not too bad though.
I did notice a bigger problem though. When I pull in the lever the pressure plate does not completely push away from the plates. Only half of it does. What could be causing this?
Back to top
Display posts from previous:
Jump to:
