Index: Carb Jetting Database
    walkmnn
    by walkmnn » Wed Mar 31, 2010 8:33 am
    Year: 2004X
    Elevation: 0-3000
    Temperature Range: 60-100f
    Smog (AIS): NO JB WELD
    Airbox Modified Top: YES
    Airbox Modified Sides: YES
    Backfire Screen: REMOVED
    Air Filter: MOOSE RACING
    Pilot Jet: 45
    Main Jet: 165
    Needle: NCYS
    Needle Clip Position: 4th
    Fuel Screw Type: CRF's ONLY
    Fuel Screw Setting: 2 1/4 out
    AP Modified: NO
    Leak Jet: 70
    AP Cover: STOCK
    Exhaust Type: STOCK
    Exhaust Modified:BAFFLE REMOVED
    Pink Wire Modified: YES
  • 1650bullet
    by 1650bullet » Wed Jun 23, 2010 10:23 pm
    8) 2005 crf250x
    Rick Ramseys jetting chart: up to 1000ft and 59-80"F
    40 pilot. Tried using a 42 but it was hard to start up (Often flooding)
    152 main
    stock jet needle 5th clip from top
    2 turns out on pilot screw
    Ap mod, I just used 2x number-4 metric o rings and set the pump screw at 2.75mm
    Air box opened out to ccc spec
    pink wire mod
    exhaust diffuser removed
    Everthing else is stock
    95-98 ron unleaded
    does not have as much bog of idle, I can be down low in third gear and just button the throttle open and instant response.(No hesitation)Im going to try a number 70 leak jet next time.The only drawback is the exhaust is a bit loud,but i can live with that. I am running 13-51 gearing because of the trails we ride, (Lots of steep hills and mountains) And im going to put the bike on the dyno and see if there have been any gains made at all.
  • MajHazrd
    by MajHazrd » Mon Jan 24, 2011 7:17 pm
    Year: 2005X, 2006 R head
    Elevation: 1000
    Temperature Range: -3 to 98
    Smog (AIS): NA
    Airbox Modified Top: Yes
    Airbox Modified Sides: Yes
    Backfire Screen: No
    Air Filter: K&N
    Pilot Jet: 42
    Main Jet: 155
    Needle: Stock
    Fuel Screw Type: Ride
    Fuel Screw Setting: 2.5
    AP Modified: Yes
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: R header
    Exhaust Modified: FMF Q4
    Pink Wire Modified:Yes
  • dbcooper
    by dbcooper » Sun Apr 10, 2011 6:15 pm
    Year: 2006 CRF250X
    Elevation: 10-100 feet
    Temperature Range: 40-100
    Smog (AIS): no
    Airbox Modified Top: yes
    Airbox Modified Sides: no
    Backfire Screen: removed
    Air Filter: No-Toil
    Pilot Jet: 42
    Main Jet: 165
    Needle: JD red needle
    Needle Clip Position: 5th from top
    Fuel Screw Type: Stealth Racing
    Fuel Screw Setting: 2 1/4 turns out
    AP Modified: yes, small o-ring
    Leak Jet: stock
    AP Cover: stock
    Exhaust Type: 2005 CRF250R
    Exhaust Modified: Stock 2005 CRF250R
    Pink Wire Modified: No
    2006 CRF250R cam
    No bogs or hesitations. Starts easy. :D
    MattBennett23
    by MattBennett23 » Sun Jun 12, 2011 9:25 pm
    Year: 2009
    Elevation: 0-2000 ft
    Temperature Range: 50-90
    Smog (AIS): Removed
    Airbox Modified Sides: No
    Backfire Screen: Stock
    Air Filter: Stock
    Pilot Jet: 42 (Stock)
    Main Jet: 158
    Needle: JD Red Needle
    Fuel Screw Type: OEM
    Fuel Screw Setting: 1 3/4
    AP Modified: No
    Leak Jet: Stock
    AP Cover:
    Exhaust Type: Stock
    Exhaust Modified: No
    Michigan rider. Just opened the airbox and added JD Jet Kit. Also removed the AIS. The bike starts great, and runs great! The bike is quick!
  • chirocrf
    by chirocrf » Fri Jul 01, 2011 10:55 pm
    Year: 2007
    Elevation: 1000 ft.
    Temperature Range: 70-95 F
    Smog (AIS): Removed
    Airbox Modified Top: Yes ccc specified
    Backfire Screen: Removed
    Air Filter: Twin air
    Pilot Jet: 45
    Main Jet: 165
    Needle: JD red
    Fuel Screw Type: R&D flex
    Fuel Screw Setting: 1 1/2 out
    AP Modified: No
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: Leo Vince X3 full system
    Pink Wire Modified: Yes
    Big Bore: Athena 280
  • F-Pilot
    by F-Pilot » Sat Nov 05, 2011 9:43 pm
    Year: 2009
    Elevation: 2500-7000
    Smog (AIS): blocked off
    Air Filter: No Toil
    Pilot Jet: stock
    Main Jet: 135
    Needle: NCYS
    Needle Clip Position: 3
    Fuel Screw Type:
    AP Modified: no
    Leak Jet: stock
    AP Cover: stock
    Exhaust Type: FMF MegaBomb and Q4
    Exhaust Modified: n/a
    Pink Wire Modified: no
    lightflight
    by lightflight » Mon Mar 05, 2012 3:21 pm
    Year:2006
    Elevation: 1500-5000
    Temperature Range:
    Smog (AIS):None
    Airbox Modified Top:Yes
    Airbox Modified Sides:No
    Backfire Screen:Removed
    Air Filter:Twin Air
    Pilot Jet:42
    Main Jet:155
    Needle:NCYS
    Needle Clip Position:4th
    Fuel Screw Type:stock
    Fuel Screw Setting:2 turns out
    AP Modified:no
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: Stock
    Exhaust Modified: Removed Diffuser
  • bruce05z
    by bruce05z » Thu Mar 29, 2012 7:34 pm
    Year:2005
    Elevation: 3000-6200
    Temperature Range: 50-80
    Smog (AIS):
    Airbox Modified Top: CCC MODS
    Airbox Modified Sides: NO
    Backfire Screen: gone
    Air Filter: athena
    Pilot Jet: 45
    Main Jet: 170
    Needle: NCVT
    Fuel Screw Type: STOCK
    AP Modified: NO
    Leak Jet: 55
    AP Cover: STOCK
    Exhaust Type: STOCK
    Exhaust Modified: REMOVED DIFFUSER
  • bruce05z
    by bruce05z » Sat Mar 31, 2012 6:23 am
    Year:2009 CA model
    Smog (AIS): BLOCKED
    Backfire Screen: NO
    Air Filter: athena
    Pilot Jet: 45
    Main Jet: 165
    Needle: NCYS
    Fuel Screw Type: WORKS CONNECTION
    AP Modified: NO
    Leak Jet: 40
    AP Cover: STOCK
    Exhaust Type: STOCK
    Cam: HOTCAMS STAGE 1
    powernow & powernow plus
    runs perfect
  • Rat64eh
    by Rat64eh » Sat Aug 11, 2012 3:59 pm
    Year:2006
    Elevation: 6m
    Temperature Range: 10-35 deg c
    Backfire Screen: NO
    Air Filter: hiflofiltro
    Pilot Jet: 42
    Main Jet: 158
    Needle: JD red
    Fuel Screw Type: R&D flex jet
    AP Modified: yes merge racing spring, shortened diaphram rod, adjusted squirter timing
    Leak Jet: STOCK (55)
    AP Cover: STOCK
    Exhaust Type: STOCK
  • ferguscawley
    by ferguscawley » Tue Aug 14, 2012 4:00 am
    Year: 2004X
    Temperature Range: 0 to 25 C
    Smog (AIS): NO
    Backfire Screen: Intact
    Air Filter: Twinair
    Pilot Jet: 42
    Main Jet: 160
    Needle: NCYR (same as 04 250R stock needle)
    Needle Clip Position: 4th from top
    Fuel Screw Type: Standard
    Fuel Screw Setting: 2 out
    AP Modified: Yes - lockwired
    Leak Jet: 55
    AP Cover: STOCK
    Exhaust Type: Leo Vince Full System for 250R
    Exhaust Modified:Full race system
    05 CRF 250R camshaft
    Runs superbly now. Nice power off the bottom although lacking in 4th or 5th gear. Gearing is 13/51 which is ideal. I might try the 270cc conversion next but right now it runs great.
  • therooster70
    by therooster70 » Wed Sep 05, 2012 6:20 pm
    [b]Year: 2012 250X
    Elevation: Sea level-1000Ft
    Temperature range:60-95F
    Smog(AIS):Removed
    Airbox modified top:Yes
    Airbox modified sides:No
    Backfire Screen:Stock
    Air Filter:Stock
    Pilot Jet:42 (all parts JD racing from kit)
    Main Jet:158
    Needle:Red
    Needle clip position:5th from top
    Fuel screw type:CRFs only
    Fuel screw setting:2 1/4 turns out
    AP modified:No
    Leak jet:55
    AP Cover:Stock
    Exhaust:Stock
    Exhaust modified:No
    Pink wire modified: No
    Better mid to full power. Pulls strong and yet is much more passive and smooth when driven lightly. No more off throttle popping. A win win situation.
    Matt
    kallekula
    by kallekula » Fri Oct 26, 2012 11:35 am
    Year: 2009
    Elevation: Sea-1000feet
    Temperature Range: -20 +80F
    Smog (AIS): Removed
    Air Filter: Twinair Kit
    Pilot Jet: 42
    Main Jet: 165
    Needle: JD Red or Blue depending on winter or summer
    Needle Clip Position: As JD recomends
    Fuel Screw Type: CRFs only
    AP Modified: ?
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: DEP S7
    Exhaust Modified: DEP S7
  • nc2wheels
    by nc2wheels » Sat Nov 10, 2012 12:38 pm
    Year: 2006
    Temperature Range: 40-110F
    Smog (AIS): Stock
    Air Filter: UNI
    Pilot Jet: 42
    Main Jet: 160
    Needle: JD Red
    Needle Clip Position: 5'th from top
    Fuel Screw Type: MSR
    AP Modified: Yes, JD Jet Thick O ring
    Leak Jet: Stock
    AP Cover: Stock
    Exhaust Type: FMF Q4
    Comments: Tuned in idle to ~1900 rpms and the bike absolutely rips. No bog, no backfire.
