by Mtngoat00 » Sat Jun 17, 2017 6:15 am
Hi all, I just got a 2016 CRF250x. After making airbox mods and adding a new exhaust I went to tackle the jetting. When I pulled the float bowl I found the pilot jet was covered by some kind of pin that has been drilled though the casing of the carb. This makes it impossible to put in an after market screw or adjust the pilot screw at all. Has anyone else found this out? Did you just leave it or try to modify to get an adjustable pilot screw in? Thanks for your help, Robert Please see the pictures below.
