That’s a good idea, thanks! I’ll try that today. Any idea what could be causing the loss of power?Welcome to the site !!
If the throttle seems "sticky" , did you happen to fall on the throttle side of the bars ??? , if so it is possible that the throttle tube and housing got pushed in on the bar , which would make the end of the grip rub on the bar causing it to drag slightly , what I would try is to loosen the pinch bolts holding the throttle assembly on , enough so you can slide it back and forth on the bar , then move it slightly to the outside of the bar maybe 1/4 inch or so to allow a little space between the end of the bar and grip , then tighten it back down , and work the throttle and see if it feels better .....
Copyright 2016-2017 © CRF's Only Forums. All Rights Reserved.
