wheelie on crf250r
  • livinmxrider22
    wheelie on crf250r
    by livinmxrider22 » Wed Mar 15, 2006 2:54 pm
    hey can ne1 help me out here?i'm tryin to get better at wheelies what is an easy way to get the fron end up n keep it up?
    450xL.W.
    by 450xL.W. » Fri Mar 24, 2006 12:24 am
    practice,throtel control and time. Sory no easy ansers to that one. Ride with someone above you're level and study their moves.
  • chief
    by chief » Tue Apr 04, 2006 4:16 pm
    what is a good gear to start a wheelie in?
    CRF250R
    450xL.W.
    by 450xL.W. » Wed Apr 05, 2006 2:07 am
    2nd it's alitle more forgiving
    05 450Xr
  • Nurser
    by Nurser » Thu May 18, 2006 4:28 am
    Keep your foot on the rear brake. If you start to tip over backwards, tap on the brake and the front end will come down. More gas to keep the front up if it is wanting to fall.
    Aspired
    by Aspired » Wed May 24, 2006 9:04 pm
    First - it is easier on hard pack or pavement than sand to practice and work on wheelies
    Second - the bigger the cc rating of the bike the easier it is to just gas it and bring the front end up - and 4 strokes are way easier to wheelie because of the torque and tractability.
    Third - On smalle cc bikes you might have to drop the clutch a bit but you should be fine on a CRF250r
    Put it in 2nd gear bring it to about half throttle (in the powerband) and crack it to about 3/4 or a bit more fast while sitting on the middle of the seat it should come up easily.
    If you want to ride it out when you get used to it you can speed shift it when it is at about the 10 o'clock position. (Practice just riding it in one gear for quite a while first though)
    and yeah keep a foot on the rear brake and remember that when it comes up and you start to lay back you have a tendance to give it more throttle automatically.
  • crf_rider.com
    by crf_rider.com » Sun Jul 02, 2006 2:33 pm
    i'm fourteen and i can wheelie my 250r with just the gas and if i want to i can use the clutch to go farther
    Crf250R
    run um hard run um stock
  • Young Gun
    by Young Gun » Tue Apr 22, 2008 6:45 pm
    I've only owned my CRF250R for about a year. I only have about 30 hours of seat time.
    I start in 3rd gear and shift up to 5th ASAP. Keepin my revs low and weight forward. If you keep your weight forward, the bike will be more verticle, but I think it's easier to balance than sitting way back on the seat. I've been practicing and so far my longest wheelie down the road has been 2.5 miles at 55 MPH. My buddy was behind me in my car during the whole thing. I can ride wheelies now with my feet over the bars, on the radiator shrouds, standing, sitting. It's all about practice. Best way to start out though is 3rd gear and slip the clutch a bit, just so you can keep the revs low. If you're revvin too high, the throttle becomes very responsive and you may end up on your back. Make sure to check your sprockets and chain tension after riding wheelies cause it'll cause your rear sprocket to "hook" and your chain will loosen and slip on your front sprocket
  • beau
    by beau » Tue Apr 22, 2008 10:20 pm
    Aspired wrote:and 4 strokes are way easier to wheelie because of the torque and tractability.
    Excellent use of the word tractability.
    :o
  • imdeeds
    by imdeeds » Wed Sep 16, 2009 4:08 pm
    Me and a friend have SLOWEST WHEELIE competitions in his yard.Lot of fun and teaches throttle,clutch,and brake control.As for what gear ANY gear works great.Stay off the road when you are riding on trails ride stand up wheelies any chance you get.
    P.S.I was 14 had an 82 480r 3rd gear with clutch on the road and looped it!Laying on the ground quickly checking wounds and a BIG guy come out of his house.He was realy mad I woke his kid up.He felt better after punching me in the nose(should of left my helmet on to lick my wounds)STAY OFF THE ROAD!
  • Furbiesandbeans
    by Furbiesandbeans » Sat Jan 09, 2010 3:30 pm
    i find it easy to pop a wheelie on hard surfaces by just hitting the gas. Throttle control is ur best advice you can get :)
  • HumboldtMX284
    by HumboldtMX284 » Sun Jan 17, 2010 9:53 pm
    slow wheelies are pretty good time
