02 CRF450R rebuild
  • blasta_15gbs
    02 CRF450R rebuild
    by blasta_15gbs » Sun Oct 29, 2017 2:37 pm
    Hello. I have a question that I'm hoping someone can answer for me. I have a 2002 CRF450R, and it threw a rod out the front of the crankcase. I found an 2004 crankcase. Will that mount up to the top end of the engine and cylinder, and will it mount to the frame right?
    Thanks,Blake
    Re: 02 CRF450R rebuild
    by JimDirt » Mon Oct 30, 2017 9:00 am
    As far as i know , the 02-04 bottom end should be a direct bolt in , though they changed part numbers the actual mount locations and size should be the same , 05-08 would be different mounting widths and would not fit without machining parts and altering mounts
    you might PM (Private Message) Ken , the owner here , as he could verify for sure if the parts interchange without alteration
    https://www.crfsonly.com/forum/memberli ... rofile&u=3
  • blasta_15gbs
    by blasta_15gbs » Mon Oct 30, 2017 9:57 am
    Ok thanks! My only concern is the bottom end i found has clutch issues! :?: Would it just need a simple clutch kit, or would it need cables and everything?
    Thanks, Blake
    by JimDirt » Mon Oct 30, 2017 4:32 pm
    Clutch itself should be the same 02-08 , the difference is where the cable mount is , in relation to the clutch actuator on the ignition side of the engine , the "clutch issue" could be just worn plates or springs , or the basket itself could be grooved since you did not specify the actual issues , but as far as parts go , you should be able to use parts from either the 02 or 04 to make it work , as far as i can remember .... 05 and later had the cable coming across from the clutch side of the engine so the actuator is in a different position and a 05 or later cable would need to be used if the cases were newer , but i believe 02-04 use the same bracket and cable , some parts are 02 specific , and 03-04 are the same (subframe , exhaust , forks , swingarm linkage , etc..)
  • Leardriver
    by Leardriver » Sat Dec 30, 2017 4:12 pm
    You are setting yourself up for frustration and disappointment.
    I would sell the parts from that bike and buy a running one for $1500. Get away from the '02 with the goofy airbox.
